Question about Home Security
I have a sentry safe, model SF123ES, I know the combo but cant open it, does the handle need to go up or down & is there a time lapse to open? I think the manual is IN the safe..
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
  • 416 Answers
SOURCE: Sentry Safe A3819
Go to
http://www.sentrysafe.com/customerCare/OwnersManuals.aspx
Find your model (pobably in safe for business)
And download the manual
Good Luck
Posted on Dec 23, 2008
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
I need to know how to erase the old combo and set a new combo. I only want the new combo to open the safe. Sentry Safe Model #472884*
I hope you registered you safe after you bought it. If not you still have a chance. Contact their support here.
They will be able to help
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 15, 2010 | Sentry Fireproof Safe
Sentry safe model 1330. i turned the dial anti clockwise 3 times, then clockwise to the No 55, then anti clock - 90, then clock - 28, then pulled the handle down. it only goes half way down and will not...
A Locksmith would say If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Feb 05, 2010 | Sentry Fireproof Safe
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH WAY TO TURN AND HOW MANY REVOLUTIONS PAST NUMBERS SHOULD BE USED. i HAVE A OLDER SENTRY VALUE GUARD SAFE, MODEL # 1330
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Sep 13, 2009 | Sentry Fireproof Safe
Get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Feb 14, 2009 | Sentry Fireproof Safe
Have Sentry 1250 safe. I have the combo but can't get it to work.
A1 locksmith will tell you.
Jan 29, 2009 | Sentry Fireproof Safe
Oct 09, 2008 | Sentry Fireproof Safe
Home Security Logo
304 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
