Question about Mag Innovision InnoVision 786 PF 17" CRT Monitor
Power light flashes with no display
I have a Mag Innovision PF-786 17" monitor, the other day I looked at it and the green power light was flashing and it had a black display. I tried to turn it off and then on again and it won't even turn off, the power light just flashes green with no display or reaction on the monitor.
  • Anonymous Mar 25, 2014
    there is a green power light on the mag monitor but no picture
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Please Cheak your V.G.A Cable.
Posted on Dec 28, 2013
  • 20 Answers
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
Posted on May 23, 2007
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Hey , i have Mag 900P monitor and i cant see nothing... the monitoe looks dead... but ther is a green light - power... should i buy a new monitor?
Hello there !
There could be a problem with the picture tube it could be dead( shorting) or the tube Transformer s damaged another course of this could be at the Horizontal section ie a Transistor or a Diode could be shorted .
Pls tell ur Technician to check all this .
Lastly Buy a new Monitor .
Good luck
Dec 05, 2009 | Mag Innovision InnoVision XJ 717 Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag lt982s no green light no power at all
try testing it in another outlet a known good outlet if it powers on then your outlets bad if it doesnt means a bad cord or bad monitor
Feb 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Does the MAG LT-456s require drivers
Perhaps your screen resolution is set too high. Try using a different display to set your resolution to 800x600, then attach the MAG display. Adjust from there once it is working...
Mar 08, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Jerome
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
No response from the monitor . Only the green light flashes. I tried with an external power supply same result
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Aug 25, 2007 | Mag Innovision LT776s 17" LCD Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Mag Innovision InnoVision 786 PF 17" CRT Monitor Logo
423 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
