Question about Plumbing
Glacier Bay Faucet valve has low flow - Plumbing
  • 171 Answers
SOURCE: kitchen faucet , reduced water flow / pressure
Hi ssam1
I'm Harvey the Master Plumber.
You want to know if you can fix a sudden low volume /pressure delivery problem on an American Standard model AS4205100 H7, one hole / single lever with pullout spray And is it fixable by owner?
Yes and maybe!
All plumbing systems are plauged with debrie buildup. Every time you turn on a faucet the water starts moving and will bring bits of debrie up from the water main or well. Most are small and will pass through to be caught by the screen in the aireator. Sometimes a relatively large piece comes along and dosen't make it through to the screen. It is stuck in the body of the valve.
Fixing takes a little mechanical ability.
First, turn off the water to the faucet in question. Then carefully disasemble paying close attention to the order of disasembly so you can reverse the order when putting back together. As each part is removed inspect it for that troublesome bit. I find that a little bit of wire or a paper clip is helpfull. Carefully reasemble. If the volume is still low then you missed finding that bit. Try again or call in a local pro.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 10, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
  • 349 Answers
SOURCE: I have a Glacier Bay(Costco) kitchen faucet. The
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
Posted on May 15, 2010
Dplumber
  • 119 Answers
SOURCE: I just installed a Glacier Bay tub/shower faucet
The faucet may be installed upside-down.
Posted on Aug 25, 2010
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Looking for an extension valve for shower faucet #108 191 Glacier Bay product.
Fixya is not a buying service. You may have to have the "plumber" redo the job; he forgot to measure the setback distance allowing for surface mounting of the escutcheon.
Nov 13, 2016 | Plumbing
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
Glacier bay faucet manual
Contact glacier bay to get a replacement control/handle assembly. Usually their customer service department is good at replacing the parts under warranty
You should have individual cold & hot water supply shut-offs in your basement for your tub/shower; if not, now's the time to install them.
If I could be of further assistance, please don't hesitate to ask.
Jul 28, 2014 | Pegasus 873-0127H2 Lyndhurst Single Handle...
What faucet manufacturer uses valve jl02bj
I have the same cartridge JL02BJ, no manufacturer name. I need to replace cartridge. Hard to find at Home Depot or Lowes.
Nov 07, 2012 | Plumbing
We just bought a house with a Glacier Bay single handle faucet in the shower. We only get scalding hot water from the faucet when we turn it on even if we move the faucet to cold. Pls help.
Hi and welcome to FixYa. I am Kelly
You need to most likely change the inner valve cartridge. These Glacier Bay valves are sold at Home Depot and finding the correct replacement part will not be easy. Personal experience is to remove the old valve cartridge and walk into the store with part in hand. These valves use a ceramic insert / disc that locks into a groove of the cartridge. If the ceramic piece has drifted out of place they usually break off the inner locking tabs.
Should the store you visit not have the part you need... read these links:
http://www.ehow.com/how_5893683_glacier-bay-faucet-parts.html
http://glacierbayfaucet.org/buy-glacier-bay-faucet-parts-online
Also read the 23 March article on this link near the bottom of the page:
http://glacierbayfaucet.org/buy-glacier-bay-faucet-parts-online Heading name is
Infromation Technology
Let me just add something........ check with your realtor about your HOME WARRANTY. This repair may very well be covered by the home warranty.
My honest opinion.... the sooner you get rid of the Glacier Bay Shower control the happier you will be. These controls were at one time Marketed under the in store name Pegasus.
I did not intend to ruin your day but... I do want anyone reading this to be advised of the consequences of buying inexpensive shore controls.
A word of advice when purchasing a new control valve. Pay for the good name ONCE and make sure the repair parts are in the same store where you make the purchase. It will cost you less in the long run. Have the sales person show you the repair parts for the MODEL that you are thinking of buying. Delta, Moen, Price Pfister are 3 names that have been around a long time and have repair parts readily available in the marketplace. (end rant)
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Home
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Plumbing Logo
199 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
