Question about Conair DPP4000 Iron
Burst of Steam
The burst of steam button isn't functioning. I have followed the instructions exactly in making sure that the iron is set at a high temp setting. Thank you for any solutions offered.
  • pcwru hotmail May 23, 2007
    The regular steam while ironing works perfectly. But, the button for an extra burst of steam for tough wrinkles/vertical steaming doesn't do anything.
  • paparichy Apr 03, 2008
    My Conair DPP4000 Iron shuts off automaticaly when I am ironing. Is there any way I can shut off this feature or contoll the ato shut off while using my iron
  • 883 Answers
If no steam at all, there is most likely a small port where some particles have clogged...fill it with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
Posted on May 23, 2007
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
No steam when ironing and no burst steam
bad connection to heating coil. Not worth fixing.
Nov 03, 2007 | Oreck Cordless Speed JP8100CA Iron
HINARI LIFESTYLE STEAM PRESS
The RED button is located on the pull down handle.
Sep 22, 2007 | Irons
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Conair DPP4000 Iron Logo
472 people viewed this question
Top Conair Irons Experts
Glenn Smart
Glenn Smart
bigdaddyd2
graybeard32301
Are you a Conair Iron Expert? Answer questions, earn points and help others
