Error code of 49.3048 on HP 4700 what is this?
  • Anonymous May 20, 2009
    We found it only did this when sending a PDF that was very large 25.7mb .....reboot isn't the way forward but just a quick fix
    Guru:
  • 829 Answers
This is a communication error. Make sure there isn't anything in the print que. If there is try deleting it. Unhook the printer from the network or computer and try and powercycle the printer. If that doesn't work try a cold reset. Turn the printer on and once the memory starts to count up press and hold the check button until the three lights light up and release then scroll down and hit the check mark on cold reset and see if the printer comes to ready. This will reset the IP address if the printer has one
Posted on Jan 05, 2009
  • febi786650 May 22, 2011
    thanks
  • dust11
    dust11 Jul 04, 2012
    An additional step (if the above doesn't work) is to leave the printer unplugged from power for at least 10 seconds, then plug it in and perform the cold reset. This was the only solution which worked for me.
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
Nikhil Gedam
  • 87 Answers
SOURCE: hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Posted on Nov 24, 2008
Thiru77
  • 33 Answers
SOURCE: hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Posted on Jun 17, 2009
  • 4 Answers
SOURCE: Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Posted on Sep 18, 2009
  • 9 Answers
SOURCE: HP LaserJet 4345mfp won't scan, but it wil fax.
This may be related to 3 problems . 1st as with all 49.xxx errors update your firmware first. 2nd it may be related to a memory problem internal to the printer. Last it may be a problem with the email server you are sending to. To troubleshoot update firmware, then remove network cable and try to scan docs is as if you were going to email. If problem does not show check email gate way. If problem does shw up replacing your memory may be the next step.
Posted on Nov 11, 2009
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
In your best soulution for fixing the 59.30 error code on a hp 4700 printer it states to remove the duplex devise from the printer. what is the duplex device and where is it located
Duplex is here:
But 59.30 error (Fuser motor startup error/Black or N/A)
Follow next instructions:
Fuser motor error
1. Reconnect the connectors J4605 for the fuser motor and J1024 on the DC controller PCB.
2. Run the component test to verify that the fuser motor is working correctly.
3. Replace the fuser motor.
Aug 01, 2011 | HP LaserJet 4700 Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
How do I fix error code 49.4C02 on a HP 4700 color printer?
This error code code comes because of outdated firm ware you just have to update the firm ware and solve the problem.
Update the firmware on the HP Color Laser Jet 4700 printer to version 20091125 46.120.4 or later. This new firmware resolves the issue.
Thanks.
Have a great day.
Oct 08, 2010 | Computers & Internet
Ho laser jet colour 4700
Have you recently adjusted or replaced the transfer belt? This error is sometimes caused by the transfer belt being installed incorrectly, so the first thing to try is to take the transfer belt out and reinstall it, then turn the printer off and back on.
If the error persists, you may have a problem with one of your motors.
Mar 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Apr 10, 2009 | HP LaserJet 4700 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
HP Lasrejet 4700
This is a tray lifting error for tray 5.
See if tray 5 is not blockt
Nov 22, 2007 | HP LaserJet 4700 Printer
9,446 people viewed this question
k24674
jasbo
jasbo
