Question about Tappan Kitchen Ranges
TAPPAN gas range model 30-3991-00/03 oven won't work.
When I press the bake button and turn the temp setting to desired temp, it shows 'on' and the temp on the display for about 5-10 seconds and then turns off. Same results with the broil mode. However, if I press and hold the bake button it will light and heat up, release button and turns off. The igniter doesnt glow unless button is held. The burners work fine on the top. I also have another tappan range that was doing the same thing so I replaced it with this one. We are wondering if it could be a problem with the gas supply?....furnace does seem to work fine though. When I first hooked this range up it did heat on its own up to about 375 and then started turning off, now wont start without holding button...same as the other Tappan range we were using.
    Sergeant:
  • 311 Answers
The button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Posted on Jan 05, 2009
Tappan Gas Range 36-30612302 oven does not get hot enough
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat to correct tempature that a weak ignitor is the cause 100% of the time
Aug 15, 2011 | Tappan TGF363 Gas Kitchen Range
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Sep 08, 2009 | Tappan Ovens
Digital oven pops breaker as oven starts to light
You have a direct short. A wire or component has touched ground .Gas or electric?electric check connections at bake and broil elements in back.Gas look for broken wire /connection at ignitor or ERC ,(control board)
Jun 20, 2009 | Tappan TGF320 Gas Kitchen Range
Hotpoint oven
Press the function you want - say bake - the set the temperature by pressing the plus sign (+) to increase the temp to that which you desire then press start
Regards
Aug 25, 2008 | Hotpoint RGB745 Gas Kitchen Range
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
397 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
