Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Lines across printed page on photos
I am trying to print photos on my HP Officejet L7580 printer. Each time I get dark lines that cut across the page at about every 7/8 inch. I have cleaned the rollers, replaced and aligned the cartridges and nothing has helped yet.
Any ideas?
  • lisaratts Feb 03, 2009
    I have an HP L75080 with the same problem. Tried changing paper size/type, still does not work. Any other solutions?
    Scholar:
  • 97 Answers
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Posted on Jan 23, 2009
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 04, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My hp printer takes avery long time in printing pages than before
Check that you haven't increased the printing resolution beyond what is sufficient to print your document.
High resolution vs. draft output will cause you to use a lot more ink and will take at least twice as long to print a page because it is likely printing each line at least twice. This is how full color (photo quality) images are printed. If you don't need a photo to be dark, then set your printer to "Standard" or "Draft" settings.
Jul 12, 2009 | HP Officejet 4110 All-In-One InkJet...
HP Officejet pro l7580 magenta won't print, new HP cartridge 8/11
You will have to reset the printer.If you want any further support, a technician from techbuddies can help you for free.For this log on to www.techbuddies.org
Jun 18, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7580
clean the printer roller, and the prin head.
go to hp.com, support and troubleshing and type in the model number. Get the user manual adn follow the direction.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
202 people viewed this question
Ben Johnson
