Question about Durabrand DWT1905 TV
Durabrand DCF2003 i have a durabrand DCF2003 TV but i am unable to change from regular channels to the tv/vcr mode , the tv does not heve any button on the front panel for tv/vidoe or tv/vcr. i have connected a dvd player to the tv using rca cables, as the dvd player only supports rca outputs and component outputs. how can i be able to change to tv/video mode . the remote does not change it either. please help
  • Anonymous Nov 03, 2007
    I have no remote to my tv and i wanna play a video game, i need the remote control code to the tv
  • Anonymous Nov 04, 2007
    I cannot change the tv to game mode from the tv menu. I see a menu that says game mode off or on but it will not work. any ideas?
All you need is to press the input select button on the remote to change between the tv and the video inputs.
Posted on Oct 31, 2007
  • Joer822 Mar 03, 2012
    Wat if u dont have a control
I can not get the tv to go back to channel 4 to watch reg tv after hooking up a Dvd player to it
Do you mean the gray CRT Durabrand from 2004? I had one of those exact ones myself recently with the remote and everything.
You need a remote control to go back to the regular channels if you're in Game or Video mode (like watching your DVD player); those inputs are entirely separate from the channels to the point that you can't use the channel left/right buttons to get out of there. In fact, before I got my remote, I couldn't even get INTO Game / Video mode; I had to use an RF modulator on channel 3. For the Durabrand 13", the remote unlocks much more out of the TV.
Jan 30, 2018 | Televison & Video
Have durabrand dct1303r tv that will not go above channel 69
you durabrand tv stay in air or tv section . so tv only showing 1 to 69 channel. you need to going to menu setup change air /tv to cable. that should be catch all channel back. good luck!
Sep 06, 2012 | Durabrand Televison & Video
HELLO!.. I HAVE A DURABRAND TV. AND I HAVE NEED
Hello You just buy one Philips CL 034 model Universal remote control, which can be programmed with your Duraband TV. The porgramme codes are
0520 0115 0317 0916 0027 0447 0323
Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one othe other codes for your brand. Ok
Nov 27, 2010 | Durabrand DWT2405 24" TV
What is the code for durabrand tv?
Hello
You just try these codes. One amoung them will wake up your tv.
0189 _0135_ 0157_
0153_ 0254_ 0458_ 0217
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 18, 2010 | Durabrand DWT1905 TV
Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Jul 30, 2009 | Durabrand DWT1905 TV
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
Lost my remote
Sometimes you can change the input by just clicking the channel button up >>> after the highest tv channel it'll go to Input 1, Input 2, etc. That's worked on one of my tv's but not all of them so it might work for you, too. Next suggestion would be to buy yourself a couple of universal remotes & keep them in a junk drawer for when you need one! We've found this PRICELESS!!! (Buy a couple when they're on sale & store them for those days when the remote was devoured by that oh-so-sneaky sofa!)
May 18, 2008 | Durabrand DWT1304 13" TV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand DWT1905 TV Logo
411 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
