Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aqarius WF740 with fault F-01
I have a hotpoint aqarius WF740. In the final spin of the cycle I heard an odd noise that made me look over at the machine. A few seconds later I saw a bright spark under the machine and the house fuse blew. There is a slight smell of burning in the air. The machine now says F-01. What has happened? The machine is only 3 years old, but we have had frequent problems with various parts. Is it cost effective to fix, or time to get a new one? Any ideas?
  • Hotpoint Master
  • 3,463 Answers
I concur with the previous assesment of the problem for error code F01, it is indeed a short circuit motor triac.
How ever , at this stage, I would suggest you remove the motor, clean the armature with emery cloth, and see if there is any obvious sign of a short circuit on the armature, if it looks o/k then I would speculate on fittng a new pair of carbons as opposed tro replacing the motor.
I have often done this myself and found in 9 cases out of ten, this does the trick.
If it still does not work , then there is no guarantee that fitting a new motor will solve the prob, as there is a distinct possibility it could have blown the pcb as well.
Then you would have bought a new motor for nothing and this would put it beyond economical repair.
Plz rate my comments.
Thanks
Posted on Jan 05, 2009
    Genius:
  • 1,036 Answers
On the Hotpoint series, F-01 is a short circuit on the motor triac. This component controls the variable amount of power to the motor.
As it has shorted out - the probable cause IS the motor itself, so I would start getting quotes for a replacement motor for this model.
Personally I would opt to swap it for a second-hand Zanussi, with a minor fault, rather than a major one like this.
If you do get a second hand-machine, buy a set of brushes for the motor to give it a new lease of life.- They're only cheap. When they fail - they can blow the motor up as I think you've just found out.
Hotpoint washer wf740 empties but will not spin
Possible the program does not move to the next cycle. Please choose a different program and see if the same result comes back. If so the controller unit is a suspect.
Finally check the drain pump, check the water level sensor and the inlet water flow so that the inputs data send is correct to the processor board..
Jul 26, 2012 | Hotpoint Washing Machines
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have an initial fill problem with a Hotpoint Aquarius Washing M
You can attempt to reset the water level, but it sounds like that system is malfunctioning and going to require service.
Oct 29, 2009 | Washing Machines
Hotpoint aqarius mod no wm63x all machine functions fine drum wont spin
check pump/filter/outlet hose is not blocked. if ok check the brushes in the motor.
Oct 21, 2009 | Hotpoint Aquarius WF220 Front Load Washer
WMF540 AQARIUS TRYING TO TURN ON AND IT IS JUST BLEEPING IT IS ONLY A COUPLE OF MONTHS OLD I MAY HAVE TURNED IT OFF LAST NIGHT BEFORE IT FINISHED ITS CYCLE???
I would advise you to ring the Hotpoint help line, the number should be in your user instructions.
Please rate my comments.
Thanks.
Jul 21, 2009 | Washing Machines
I have had aqarius a hotpoint aqarius 1000 wm62p
It has a wide variety of wash programmes for white cotton, colourfast cotton, polyester, non-colourfast cotton, wool blends and wool itself. These standard programmes take from an hour and a quarter to three-quarters of an hour to complete.
There is also a quick wash programme lasting just under half an hour for lightly soiled items and a pre wash soak for heavily soiled items. The machine has four buttons providing extra facilities that can be set independently of the main wash programmes to give you a more comprehensive range of settings.
There is a rinse hold button, which I find extremely useful. When set this holds the clothes in the final rinse water until you are ready to unload the machine. You then release the button, let the machine go through the final spin and then you can unload the machine. It means that you don’t leave damp washing in the machine for the time between the cycle finishing and you unloading the machine, which would make for very creased clothes. There is also a button to depress if you want to use the super rinse facility. This merely increases the volume of water in each rinse so that the clothes are rinsed more fully. I have never used this particular facility, as the ordinary rinses are fine for my needs.
The next button allows for a slow spin. I find that this one is really useful for the items that I need to iron as it means that they don’t come out of the washing machine as creased as they normally would on a faster spin. The only problem with this is of course that the clothes are not as dry as they would otherwise have been. The final button is used to set the economy wash feature. This means that the washing machine’s own heating system is not used and the wash is done with the water at the temperature entering the machine from your hot and cold water tanks. This of course means a cooler wash so it’s only suitable for lightly soiled items.
The door remains locked during the wash programmes so that it cannot be opened accidentally and it can be locked when not in use too if you have small children who might get into mischief! The other big selling point for this particular model is that it gauges the size of the load and uses the correct amount of water needed eliminating the need for the half-wash programme. This also means that it is both water and energy efficient
Mar 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
2,442 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
