Question about Sharp Shar El501xbwh El 501X Basic Science Ca
How to multiply exponent on sharp el 501x
Looked at official site, google for 30+ min. Cannot find answer on how to multiply exponents on my Sharp el-501x calculator.
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: exponential form
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 06, 2008
SOURCE: Sharp EL- 531WB- BK Scientific Calculator
rectagular form eqations
Posted on Aug 19, 2008
  • 7993 Answers
SOURCE: how do i display very small exponents on the sharp
You have several number display formats : Normal1, Normal2, Sci, ENG
If a number is too small or too large and the calculator cannot display it with the necessary number of digits (to satisfy your of decimal digits) the calculator uses Scientific notation
7.4E-14 =7.4x10^(-14)
If you were to use the norma1 or normal2 format you will have
.0000000000000074 but your calculator displays only the first 10 places
You should learn to use and interpret results in scientific format.
Hope it helps
Posted on Sep 07, 2009
SOURCE: how do i display exponents besides 2, or 3 on the
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Posted on Sep 10, 2009
The exponent function automatically displays and multiplies by 10. How do I turn this off?
Here is the manual in PDF format. Simply search the documant once loaded by holding the "CTRL" key and pressing "F" this will bring up a search window. From there type in the search window "exponent" there are 6 different mentions of it. the 4th one gives you directions.
I hope this helps you.
http://www.yorku.ca/ntahani/ADMS3530/EL738_OM.pdf
Feb 18, 2015 | Sharp EL-738 Financial Calculator
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
How to plug in exponents on sharpe EL 501X calculator
Type in your base and then press the button that says y with an x as an exponent (last row of the small buttons, second from the left). and then type in your exponent.
Apr 09, 2014 | Sharp Shar El501xbwh El 501X Basic Science...
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
Where is the exponent key on the 531x
If you mean the key to raise a number to an exponent, it's the key marked "y^x", two keys above the "7" key. If you mean the key to enter an exponent of ten, it's the key marked "Exp", just above the "7" key.
Feb 18, 2013 | Sharp el-531x scientific calculator
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
Mar 10, 2012 | Sharp Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
How do i display exponents besides 2, or 3 on the sharp EL-531WH?
EL-531W SHARP:
Jul 04, 2009 | Sharp EL-531VB Calculator
Exponential form
EL-531 W
Aug 05, 2008 | Sharp EL-531VB Calculator
Sharp Shar El501xbwh El 501X Basic Science Ca Logo
919 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
