Question about Toys
G scale one hook is missing need replacement
Got it as gift in 1985 need to know where to get replacement part
  • 91 Answers
Buy it online through e-bay
Posted on Jan 05, 2009
I was given as a gift one of your scales and it does not work properly. I cannot weigh myself or anything else.
Donna, FixYa is not the company that manufactured or sold your scale. So, to help you, we would need to know the Brand/Manufacturer and the Model Number. With that information, we may be able to furnish you with and Owners Manual.
Please advise.
May 16, 2011 | Health & Beauty
We just put a new battery into our 1985 Chevy S10. Now none of the lights work and nothing in the cab works but it starts. What do you think could be the problem.
i would have to guess that you missed putting a wire on the battery or you have a broken wire that hooks to the battery.
Dec 17, 2010 | 1985 Chevrolet S-10
1985 Yamaha Maxim XJ700 battery drain
Hi, Jp_richar82 perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging and it must be able to pass a proper "LOAD" test you may have cursory readings of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries have this issue more so than lead acid types.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. The meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your multimeter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe multimeter for a drop in amperage then get out your test light and track down the short in that circuit.
5. Hook up the multimeter to the battery set it to DC volts and start the engine if multimeter falls below 9.0 volts while cranking you need to perform a proper load test on the battery and replace if necessary.
6. With the engine running at 3600 RPM, the battery should read 14.3-14.7 volts if not continue tests.
7. Unplug the voltage regulator from the alternator at crankcase by the front of the primary cover.
8. To test voltage regulator go to
9. With the multimeter set to the ohms scale, with one lead grounded, touch an alternator pin ohmmeter should read infinity, if not replace the stator.
10. With both leads touching alternator pins, multimeter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace the stator.
11. With the multimeter set on AC volts scale, both leads touching alternator pins multimeter should read 16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace the rotor.
12. Check for excessive wattage load from headlight
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Electrical Battery Issues 1985 xj700
Yamaha XJ700N Service Manual
OEM Parts for Kawasaki
May 30, 2010 | 1985 Yamaha XJ 700 S Maxim
Missing a part on the tension belt for a Nordic Track Achiever
Go to click on manual input Nordic Track Skier their is 47 matches the friction band tensioner should have a clear diagram of that mechanism
May 29, 2010 | Exercise & Fitness
Toys Logo
106 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
