Question about Electronics - Others
My PNY 64 GB flash drive is not recognized by my computer, when I insert it in the port nothing happens
  • 26 Answers
SOURCE: Unable to access files on the flash drive
SDHC cards are not backward compatible with normal SD cards..therefore older devices will not recognise them...your built in card reader is probably not sdhc...try downloading directly from camera or use a sdhc usb card reader
Posted on Apr 29, 2008
SOURCE: pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
Posted on May 28, 2008
SOURCE: My computer does not recognize my new Ativa 16GB
my computer does not recognize my ativa 8gb stick
Posted on Nov 17, 2009
laikexpert
  • 281 Answers
SOURCE: pny 16gb attachi flash drive reccognized by my
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 31, 2010
rulds2008
  • 3866 Answers
SOURCE: My PC will not recognize PNY USB 2.0 4G drive. It
What you need to do if you using windows XP is you need the mass storage driver for this to reconised the drive. Link is below
http://support.microsoft.com/kb/318812
Now if you using say windows vista,windows 7 and you get a error message saying that the usb has failed or the thumb drive is not recognizable then chances are the thumb drive is bricked, meaning will not accept in coming and outgoing communications. This hap pends when your using XP and you just unplug the drive without using the safely remove device button on the task bar.
While Bob's information refers to anything usb and your product is flash memory and not just anything meaning its not powered by any cords nor does it have any cords I thought i might add addition helps.
Hey Thanks for dropping your issue on fixya we love helping people and we love recieving your feedback, So it would be decent that you leave us just that. Thanks for using fixya.com
Posted on Apr 14, 2010
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
The driver, it is not on my computer
USB Flash Drivers are an automatic install and so should work out of the box. If they aren't then can you try another flash drive? Can you also try and use another known working device in that same USB port? Is it the USB port that is damaged? Does the PNY work in another computer?
Oct 29, 2014 | Acer Aspire 4530-5889 Notebook PC
When I insert my PNY flash drive 64 GB my computer doesn't recognize it, nothing happens
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Nov 08, 2012 | PNY Attache 64GB USB Flash Drive
Just purchased a pny 4gb fashdrive for a MacBook. It is noy recognized on either USB port
is it compatible to the USB technology ? as in USB 2.0 vs. USB 1.0
try the flash drive on another computer , sometimes if you format the flash drive (Insert into USB connection, right click and press format) -- that may work
let me know please.
Nov 03, 2010 | Apple MacBook Pro Notebook
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I have a pny 4gb usb 2.0 flash drive black.instructions needed.
Most USB drives are "plug n play" meaning you just plug it in to a USB 2 port and your operating system will recognize it as a drive. If you're using Windows ME/XP/Vista, just plug it into a USB 2 port and once its recognized you'll be able to send files and folders directly to it by right clicking the file or folder and moving your mouse over SEND TO and selecting the drive from the list.
Nov 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Usb not recognized?????????
The USB port in which your flash disk has been inserted muight be damaged. Try inserting it in another port.
Oct 22, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
Electronics - Others Logo
363 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
