Need a 1AA4B10N2020A (key controler) for a Sanyo DP50747
Controller shows: PWB.CONTROL.N4SG 1AA4B10N2020A Looks to be a 5 switch controller with a 6 pin connection point.\
3 Suggested Answers
  • 17 Answers
SOURCE: I need a replacement part.
hey i know shopjimmy carries key controllers for sanyo, you should check them out here is there site www.shopjimmy.com
Posted on May 08, 2009
SOURCE: remote control code (5 digit) for Viewsonic N3251w
This Works For My Viewsonic N4621W Code 10054
Posted on Jan 31, 2009
What is error code c/6 400 on koycera km2020
Developer unit
MCY
1. Check that the developer waste lock has
been released and, if not, release the
lock (see page 1-2-15).
2. Check that the gears and spiral screw of
the developer unit are not damaged.
3. Confirm that the developer roller can
rotate.
4. If it won't rotate, replace the developer
unit (see page 1-5-57).
Developer motor
MCY
1. To check the motor operation, execute
DLP(MCY) by U030 (see page 1-3-34).
2. Check the drive gear can rotate or they
are not unusually loaded and, if
necessary, replace.
3. Confirm that the wiring connector is
firmly connected and, if necessary,
connect the connector all the way in.
Developer motor MCY and Motor
control PWB (YC7)
Motor control PWB (YC3) and Engine
PWB (YC9)
4. If the wiring is disconnected, shorted or
grounded, replace the wiring.
5. Replace the Developer motor MCY.
Motor control PWB Replace the Motor control PWB
Engine PWB. 1. Check the engine software and upgrade
to the latest, if necessary.
2. Replace the engine PWB (see page 1-5-
80).
Aug 07, 2014 | Kyocera Office Equipment & Supplies
I need a key controller 1AA2BUM0052 for a model DS19630 Sanyo TV
You will be lucky to find the original remote---they do not sell parts for remotes for specific sets
Oct 30, 2012 | Sanyo Televison & Video
When I connect my Sony Google TV to my SANYO TV through a HDMI cable, it does not work. Please any suggestions? SONY TV model = Sony RMVZ320 Remote Control SANYO model = SANYO MODEL DP50747 ed it int
First of all, be sure that your SANYO TV is on the correct input for the HDMI port you're using. If that checks out, you might check to see that another device (e.g. blu-ray player, laptop, cable receiver, etc...) works with the SANYO TV using that same HDMI cable and port. If it does work, perhaps your Google TV box is set for a higher resolution than your SANYO TV supports.
Aug 11, 2012 | Sony RMVZ320 - RM VZ320 Universal Remote...
Dnttv cuts on and off will not stay on, found the problem circuit board broke serial # 1aa4d10n202oa how can i order another one
Are you sure of the part number? I do not see a 1aa4d10n202oa among the parts for the Sanyo DP42848. I did find the 1aa4b10n2020a (key control) from several sites but there is a 3 digit prefix on the part number at Shop Jimmy . com among others. (Not all sites have this in stock.)
I hope this helps.
Jul 11, 2011 | Sanyo DP42848 LCD TV
My 50'' sanyo dp50747 when i trun it on it changes channels by it self
U probably have a depresed buton on the control panel of ur tv. U can open it and pop it back into position. If the problem persists, call a technician to look at the control panel, it wil be faulty and need to replace a few components. Good luck.
Jun 19, 2011 | Sanyo DP50747 50 in. Plasma TV
Fault code 116-324 what can i do to fix this problem
116-324 System Controller RAP
An exceptional Controller error shut down the processor.
Initial Actions
Power Off/On
Procedure
Pull out and insert or replace the DIMM (PL 11.2).
If the problem persists, replace the ESS PWB (PL 11.2).
116-325 ESS Fan RAP
The ESS fan failed.
Procedure
Replace the ESS fan (PL 11.2).
Apr 30, 2011 | Xerox WorkCentre 7132 PCL 6
How to restart my sharp 2530 copier
H5 indicates a heat problem in the FUSER. You need to call a Service Tech.
Nov 27, 2009 | Sharp Office Equipment & Supplies
Contact the link below. They will guide you to have parts. If the set is obsolete, it will be very difficult to have parts.
http://us.sanyo.com/components/
Jerry G.
May 10, 2008 | Sanyo DP26746 26 in. LCD Television
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
