I turn on my dell ispiron 1720 and it says i need a system or administrative password
It doesnt even let me go to the boot menu or setup menu, and if i trymore then like three times, an incorrect password it turns off
  • 58 Answers
According to me if you are not able to access boot menu then it is difficult to reset password manually. So you can use password recovery software (click http://lmgtfy.com/?q=Reset+Windows+Password+stellar to search) to reset windows password.
Posted on Nov 12, 2012
  • 61 Answers
Did you try no password?
Posted on Nov 09, 2012
SOURCE: need system unlock code for dell latitude
do you have the customber number or invoice number for the product?
Posted on Apr 07, 2008
frcs68
  • 1605 Answers
SOURCE: Remove BIOS sytem password
Power down the laptop. take a pen and paper and write down what you rementber as the password that you put in.
remember; the password is case senstive.
This a safe way to do it. since Dell have put in non-volatile chip for the BIOS password. you have to disasseble the laptop and in order to reset the password.
so, try to remember and see if the password that you wrote down makesense. and try again
Posted on Dec 01, 2008
SOURCE: Cannot identify Battery
Hi
Please update your system using this file and if this does not work try to reseat the battery and check.
If you are using vista download the file to desktop. Right click. Click on run as administrator. Let me know if this resolves your issue or you need more help.
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=264350
Thank you
Rakesh
Expert Dell Laptops.
Posted on Jan 06, 2009
brannfenix
  • 81 Answers
SOURCE: hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Posted on Jul 28, 2009
  • 6 Answers
So I bought a Latitude D620 and I bet u heard this a million times already it came with the famous This system #xxxxxxx-xxxx, is protected by a password authentication system. Any help from the gods of this site would be appreciated. below are the numbers needed i believe,
CHZ0P2J Service tag
272-081-320-75 Express code
This system #CHZ0P2J-595B is protected by a password authentication system.
Any help would really be appreciated. thanks in advanced.
Posted on Dec 20, 2009
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
How do I boot to windows or disable bitlocker?
Anonymous,
Steps to Turn On/Off BitLocker:
Click the Start button to view the Start Menu and then choose the Control Panel option.
The Control Panel window opens up.
Now click the System and Security link from this window.
The System and Security section of Control Panel opens up and you can see the direct link for the BitLocker Drive Encryption.
Click on the BitLocker Drive Encryption and a new window opens up.
By default the BitLocker Drive Encryption is Off for the Hard Disk Drive. Click Turn On BitLocker. If a compatible Trusted Platform Module.
Note: To use BitLocker Drive Encryption, your computer has to meet certain hardware requirements.
Otherwise, this opens the BitLocker setup wizard. Follow the instructions in the wizard. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 07, 2014 | Dell XPS M1530 Notebook
Bios password
deepak,
You can create an administrator password by creating an administrator account in Windows. You can also add a BIOS password by entering the bios. (press F2 to enter the bios while booting up the system). Once in the bios tab down to the security screen to add password.
Thank You,
Dell-Jesse L
Sep 16, 2013 | Dell Inspiron 630M Notebook
ADMINISTRATOR FORGOT PASSWORD PROBLEM FOR MY LAPTOP DELL INSPIRON 1720
One of my friends also has DELL INSPIRON 1720 and he faced same forget password problem. He used password recovery software (I guess it was Stellar Phoenix Password Recovery Software) to successfully reset his administrator password. I think such software can help you too.
Sep 28, 2012 | Computers & Internet
Forgot the administrator password to my dell inspiron 1720or the systems name how can i byepass it
This happened to me before but can no longer change the admin password, so I have no choice but to create a differen user and delete the old one. Here's how I did it:
1. Restart you computer
2. Press f5 before the windows logo appear
3. Select safe mode
4. Click start menu
5. Click control panel
6. Go to User aacounts
7. You can. Ow delete that account and create a new one
Hope this helps
Oct 09, 2011 | Dell Inspiron 1720 PC Notebook
Administrator password Dell Inspiron 1720
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
Sep 30, 2009 | Computers & Internet
Password help
Entering the System Setup Program
1 Turn on (or restart) your computer.
2 When the DELL™ logo appears, press <F2> immediately.
3 If you wait too long and the operating system logo appears, continue to
wait until you see the Microsoft® Windows® desktop. Then, shut down
your computer and try again
On each screen, the system setup options are listed at the left. To the right of
each option is the setting or value for that option.
You can change settings that appear as white type on the screen. Options or
values that you cannot change (because they are determined by the
computer) appear less bright.
The upper-right corner of the screen displays help information for the
currently highlighted option. The lower-right corner displays information
about the computer. System setup key functions are listed across the bottom
of the screen.
The system setup screens display the current setup information and settings
for your computer, such as:
• System configuration
• Boot order
• Boot (start-up) configuration
• Basic device configuration settings
• System security and hard drive password settings
the password is under System security
Mar 06, 2009 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
