Question about GE Refrigerators
The ice keeps crushing ice when its one cub - GE Refrigerators
    Top Expert:
  • GE Master
  • 9,472 Answers
There is a little lever which freezes in the crush position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place.
Posted on Nov 08, 2012
5 Suggested Answers
TheRepairGur
  • 27 Answers
SOURCE: my ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Posted on Apr 28, 2009
  • 64 Answers
SOURCE: Crushed ice dispenser not working
remove bin and all ice. clean out bin with warm water as it is not shifting ...jambed with ice/snow
Posted on Aug 26, 2009
  • 112 Answers
SOURCE: ice maker will only crush, won't let you get cubes
The dispenser door is staying open and allowing warm moist air back inside the freezer. This are is causing the frost to build up in your ice bucket.
You will need to put your finger up into the dispenser and push it shut. The other option is to get the dispenser solenoid replaced.
Good luck.
Posted on Jul 25, 2010
TheMobilian
  • 8220 Answers
SOURCE: Wwe have a french door
I have yer service manual right ova Heah!
Posted on Aug 28, 2011
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Crushed ice mode seems stuck - want cubes but keeps crushing.
jeff, at one time the ice bin was removed and there is a rod on the bottom of the bin remove the bin and you'll see an opening where the arm will fin the square plastic looking assy is probally stuck in the up position pull it down with you finger and reinstall the bin the it should work
Aug 19, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
The ice maker drops the ice into the chute but when it should come out of the chute the flap keeps the ice backed up.
It's probably just frozen up with crushed ice. We use a lot of crushed ice and we clean ours out every night before bed time. That way we can start a whole new day of "Crushed Ice Pleasure" without the backing up. If this is not your case, your chute may need to be replaced. We have parts! Hope this helps you! Ella
Aug 18, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
May 28, 2009 | Whirlpool ED2GHEXN Side by Side...
My ice-maker keeps switching to crush on it's own.
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
No crushed ice
  • pull out the auger assembly (big plastic tray with a metal coil in it that holds the ice) and dump all the ice out.
  •  clean out the whole thing and let any ice residue melt, then try it.
  • sometimes a small amount of ice will buildup around the ice crusher and keep it from engaging.
Jun 29, 2008 | Frigidaire FRS26KF5C Side by Side...
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
