Question about PNY Attache 64GB USB Flash Drive
When I insert my PNY flash drive 64 GB my computer doesn't recognize it, nothing happens
  • PNY Master
  • 27,725 Answers
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Posted on Nov 08, 2012
2 Suggested Answers
tibys
SOURCE: how to fix PNY USB flash drive
Salutare bai Lucica... Vad ca ai probleme.. cu stick-ul :)
Daca ti-l vede ca unitate, in My Computer, descarca HDD Low Level Format Tool de pe http://hddguru.com/ .... descarci, instalezi si ii dai o formatare low level la stick... o sa zbarnaie dupa aceea... multa bafta
Posted on Sep 22, 2012
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
The driver, it is not on my computer
USB Flash Drivers are an automatic install and so should work out of the box. If they aren't then can you try another flash drive? Can you also try and use another known working device in that same USB port? Is it the USB port that is damaged? Does the PNY work in another computer?
Oct 29, 2014 | Acer Aspire 4530-5889 Notebook PC
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
I have 3 pendrive first & second pendrive of transcend & croma is not recognised pny 4 GB pendrive it shows (please insert a drive into F)
try using this software to format the transcend pendrive . use it in XP or Vista www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
Aug 14, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Kingston DataTraveler 64GB USB is not recognized by pc or laptop
Hey hi dude. As far as i heard, 64 gb drives are error prone to a greater extent. In some cases it is just showing 32 gb of storage space for the user. So better go to a nearby Kingston Service center and claim for a New replacement for your Pen drive. Am really sorry to say this. But there is no other go. Kingston provides you a nice customer service. Within one week, you will get a brand new drive as a replacement for your drive. Believe me!!!
Aug 02, 2010 | Televison & Video
PNY 8GB Flash Drive - PC Will not recognize
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
Oct 03, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
PNY Attache 64GB USB Flash Drive Logo
184 people viewed this question
Top PNY Computers & Internet Experts
David
David
marley mcelhinney
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
