Question about Sony CMT-HPX9 CD Shelf System
I have a SONY CMT-HPX9 Micro component Hi Fi System and the drawer which holds 5 cds won't open. Any ideas how I can fix this? Thank you. Bob
  • robert_levy Jan 05, 2009
    My posting as robert_levy has still not received a response as yet....
    can anyone solve this?? Thank you---R. Levy
5 Suggested Answers
SOURCE: MIcro HI-Fi CMT-HP7
clean the laser lens
Posted on Jul 04, 2009
hmerchant110
  • 7191 Answers
SOURCE: Sony Micro Hi-Fi CMT-M373NT User Guide
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Feb 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have lost the remote
It's a rm-srg440.
a replacement:
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=Sony+CMT-HP7&uuid=A13088260342941
eBay has several originals cheaper.
Posted on Jun 23, 2011
gopakumarg43
  • 74666 Answers
SOURCE: micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Posted on Jan 24, 2012
CDs won't play
The problem is in the laser pickup assembly, try cleaning the laser lens with a Q-Tip and rubbing alcohol gently, allow several minutes to dry, if this fails the whole assembly must be replaced, not cost effective to repair cheaper to buy.
May 09, 2012 | Sony boom box micro midi mini-fi systems...
My cd player does not play music in order, instead of 123...it skips to 5 than 8 etc.
There's a control under PLAY MODE that selects random play labeled "1 DISC SHUF". Normal play would be "ALBM". Read the manual.
http://www.retrevo.com/support/Sony-CMT-HPX9-manual/id/268dj180/t/2/
Jul 18, 2011 | Sony CMT-HPX9 CD Shelf System
Sony CMT-hpx7 - CD changer is stuck with 2 CDs inside. Any ideas how to open it without destroying either the CDs or the stereo? Any help would be appreciated!
it a bit complicate to open
you can try but you need to remember what you open so you can put back in the same order
try this
first open the back cover you should be able the see the inside then you need to open the top cover now the changer can be open without power you need to locate the motor and turn the the belt or the wheel slowly and it wil take the disc out. """"""dont turb back""
you need to plug the power and let it go back alone after that disconnect the power and put back everything
its not so easy so before you do it make sure that you can open and put back
Hope it will help
Aug 24, 2010 | Sony CMT-HPX9 CD Shelf System
CMT-HPX9 CD Shelf System: I need the manual...
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 06, 2010 | Sony CMT-HPX9 CD Shelf System
Micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
My Sony CMT-HPX9 has no sound
If it's not the mute, try replacing the output fuse. Did you hear a POP last time it was operating? Good luck
May 28, 2006 | Sony CMT-HPX9 CD Shelf System
CD problems
hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Mar 26, 2006 | Sony CMT-HPX9 CD Shelf System
Sony CMT-HPX9 CD Shelf System Logo
59 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
