Question about Refrigerators
My wine cooler is making a noise everytime the fan on the motor comes on.  Can you help me?
  • 163 Answers
Hi!! what kind of noise..might be coming from your fan..turn it on and off if you hear that noise everytime you turn it on and off then your evaporator fan is going bad..good luckk.
Posted on Jan 05, 2009
Danby wine fridge making noise
If I checked out the right video it sounds like a fan motor. After a fan motor heats up and with age the fan will leak a little oil, the oil will become to thin and not cote the bearings well enough. It sounds like the fan trying to start back up after stoping. I would track down the fan motor and replace it.
Apr 09, 2014 | Danby DWC283BLS Wine Cooler
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
My Danby wine cooler fan is making a horrendous noise - it sounds like it's trying to start up and then it gives up. I hav tried tightening the housing screws but this works for a couple of minutes and...
Where is the noise coming from? Check the fan at the back of the upper compartment. They seem to be defective and die after about 3 years (just outside of warranty... how convenient). I'm dealing with the same issue now. (As search on the internet indicates that we're not alone!) When its making that noise, try pressing the back plate around the little fan and see if it changes the noise.
Apr 11, 2011 | Danby DWC283BLS Wine Cooler
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
Motor in wine frige is noisy???why
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
Aug 31, 2010 | Haier BC112G Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Haier wine cooler produces intermittent loud "motor" noises.
Turn the unit around so you can hear the compressor (large black small basketball size unit lower left) if the sound is coming from that then it is probably lost lubrication or just failing. "These usually last forever but.... they do fail. I am not sure if this one (loke mine) has a samll fan. Clarify the noise for use and we can tell you what it is. a constant tapp tap tap fast paced is the compressor going out or out of lub etc. . A ting ting ting may be a fan... Robert-Aptos
Apr 28, 2009 | Haier BC112G Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
