Question about Sharp el-531x scientific calculator
How do i get my EL-510R to clear all modes?
It says SCI DEG on the screen 0.00000000000 x10 the decimal place wont move it stays in second place.
SOURCE: decimal places too long on EL 531 W
change the mode to normal i.e. press the 2ndF key,MODE, 0
Posted on Dec 09, 2008
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
SOURCE: How do I set the
Click on the link below to download the Sharp EL-1197P III owners guide:
http://www.scribd.com/doc/30938397/Sharp-Calculator-EL1197PIII-User-Guide
Posted on Aug 26, 2010
  • 7 Answers
SOURCE: Sharp El 738 - want
http://www.yorku.ca/ntahani/ADMS3530/EL738_OM.pdf
That is the manual, on page ten there are many options for you to use in customizing your calculator for decimal places
Posted on Jul 25, 2011
  • 102366 Answers
SOURCE: remove decimal places from el-735
Press [2ndF] [TAB] [.].
If you need a manual, you may download one here.
Posted on Mar 24, 2012
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
Where's the SIC button located on the calculator? is there one?
Sorry. I am a loss about what that SCI means. However if you are asking about SCIentific display mode you can access it by pressing [SHIFT][MODE]. It will be listed as SCI. Press the number to its left. You will then be prompted to enter an integer number between 0 and 9 to specify the number of decimals digits.
To enter nummbers in scientific notation, enter the decimal part (mantissa) then use the key marked x10^x followed by the exponent.
Aug 12, 2011 | Casio fx-300ES Calculator
How can i get fix off my calulator
To get out of the fixed decimal mode, press the MODE key until you see the screen giving you the three options "Fix", "Sci", and "Norm". Select Norm 1 or Norm 2. If you select a Sci mode, you'll get "SCI" on the screen in place of the "FIX".
Jun 23, 2011 | Casio FX-300MS Calculator
HOW CAN I GET FIX AND REG OF MY CALULATOR.I AM USING FX 300MS.
Press MODE 1 to get out of the regression mode and into the standard calculation mode.
Jun 23, 2011 | Cameras
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
Get it out of scientific mode!
  1. Press [MODE] .
  2. On the top line that says Normal Sci Eng use left arrow to move highlight from SCI to NORMAL an press [ENTER] to validate the setting.
  3. After that, you must set the number of decimal digits: use down arrow to move cursor to second line. FLOAT 0 1 2 3 4 5 6 7 8 9
  4. Use left or right arrow to highlight the number of digits you want. If you want 2 decimal digits, move cursor or 2 and press [ENTER]
  5. Press [2nd][QUIT] to exist the [MODE] screen.
Feb 10, 2010 | Texas Instruments TI-83 Plus Calculator
Decimals wont show
You need to change the display format.
Press the [MODE] key a certain number of times until the screen displays Fix, Sci, Norm on one line, and 1 2 3 on the next line, with 1 under Fix, 2 under Sci and 3 under Norm.
Press 1 (Fix) followed by a number (1,2,3, etc.) This second number will set the number of decimal digits. In other words, if you press 1 (Fix) 3 all your results will have 3 decimal digits. If you choose 0, your results will not show decimals.
Hope it helps.
Thank you for rating the solution.
Dec 04, 2009 | Casio FX-300MS Calculator
Oops
Hope it helps.
Nov 05, 2009 | Casio FX-300MS Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
Sharp el-531x scientific calculator Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
