Question about Zebra Symbol MK500 Data Terminal
MK500 device goes off during power outage, when it comes back on, Everything is back to factory setting, is there a way to permanently save modified files on it? please help
Choosing a home generator to use in the event of outages
if you can afford a real standby genset id get one of those. reasoning is this way you do not have to store gasoline and rotate it every few months. and if you have a backup style genset you may not be able to get fuel for it when your supply runs out. that and you have to hook it up when the power goes out. safely hopefully. they are sized depending on the size of your power needs. most places that sell them will come to your house and tell you what youd need. easy stuff
Sep 17, 2017 | Electrical Supplies
Sony CDP-CX450 Cd Player
As in most current devices, absence of power (as in shortages/outages) simulates a reset. The reset reverts the unit back to factory defaults which of course does not have user configurations and settings.
A workaround perhaps would be with the use of a UPS as those used in computer systems.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Sony CDP-CX450 400-Disc CD Changer
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
Frigidaire GLHS269ZCB4 after power outage Freezer not cooling fridge warmer hear the fan click and short cycle
Hello Wayne, thank you for allowing me to assist you. Was the freezer unplugged during the power outage? If it was, here are some simple troubleshooting steps you need to take:
It is best to unplug the unit and wait for the power to come back on.
Next, turn the control to off (or digital display), plug the unit in and reset control to factory-suggested setting.
Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the refrigerator plug is tightly pushed into electrical outlet and not plugged into a GFI.
If your unit has no power and it is not due to a power outage, check the following:
Verify that the temperature control is set to the OFF position.
Set temperature controls to proper setting suggested by your owner's guide; or set to the halfway point and adjust it up or down as needed.
If these basic troubleshooting tips prove ineffective, the power loss may have possibly caused a communication problem with the control board, temperature control or wiring harness. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Aug 23, 2013 | Frigidaire FRS26KR4A Side by Side...
Save network configuration in mk500
[HKEY_LOCAL_MACHINE\Comm\SMSC92111\Parms\TcpIp]
"WINS" = multi_sz: ""
"DNS" = multi_sz: ""
"DefaultGateway" = multi_sz: "10.3.1.1"
"Subnetmask" = multi_sz: "255.255.255.0"
"IpAddress" = multi_sz: "10.3.1.72"
"EnableDHCP" = dword:00000000
save as "ipaddress.reg" copy to Applcation drive and restart it
Dec 29, 2012 | Zebra Symbol MK500 Data Terminal
How to hardware reset for motorola MK500
There is a way how to do it. Actually I don't want to spare in public forum, as this could lead to unpleasent effect - Like unapproved person comming to (your) shop and reseting devices.
Just check the site support.symbol.com for MK500 and if you are a technician, you will find your answer quickly.
My apologize to people searching for the easy solutions. This is only for technicians.
Jun 04, 2010 | Zebra Symbol MK500 Data Terminal
Stuck at 288 degrees
NO PARTS REQUIRED!!! DON'T PAY FOR A SERVICE CALL!!!
After a power outage, my wife's grandmother said she could no longer set her over to 300, 400, 450, whatever..
I went over to troubleshoot.
I couldn't figure out why everything seemed functional and why I couldn't set the over to higher than 288 (and thought, that's a rather odd number)... until I realized that that 288 degrees C = 550 degrees F which is the max the oven can do.
The power outage reset the computed back to celcius instead of fahrenheit.
Save them a ton of money... cause this could have been an easy cash grab to some cook out there.
May 01, 2009 | Kenmore Kitchen Ranges
Cannot access the internet
try this :
1. it seems that the power outrage had caused your wireless settings to be restored to its factory settings .... so there is a need to reconfigure it again ...
the settings that are saved to my computer do not match" --- this usually pertains to the network settings saved on your laptop, if it is vista you must delete the old profile,it also applies for xp OS ....
VISTA :
>network and sharing center
> manage wireless connections
>under networks you can view or modify, highlight the old profile then remove
XP :
>netowrk connections
> right click on wireless network connection and go to properties
>click on wireless tab
>under preferred networks (box in the middle) highlight then remove
2. to check this do ipconfig on the cmd line
•check the default gateway if it is still 192.168.1.1 or 2.1 ( the default gateway is the rtr's address)
•open your browser, then type the rtrs ip
• leave the username blank, password is admin ( small caps)
• then you are in the set up page
• check the wireless tab, and very the ssid if it is still or the name of your network which you used to connect to ...
• just save the settings if you want to make changes
****** very impt : while doing this changes, your main pc or dsktop pc must be hardwired to the router ,, never make changes wirelessly coz the connection is very instable you will be kicked of everytime ..... ***********
GOOD LUCK!!!!!
Oct 21, 2008 | Linksys Wireless-G WRT54G Router
Ups troubles
What is happening here is you are transferring load to battery during a power outage but on return of Line Power the UPS is not smoothly transferring back to Normal mode. As a result you are basically turning off your computer. Two options... shut down your computer orderly during an outage or buy a new UPS.
DD
Dynamic Power Solutions LLC
Aug 20, 2008 | Computers & Internet
Zebra Symbol MK500 Data Terminal Logo
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
