Question about Fujitsu FMV lifebook TH40/D
Is there a way to increase its RAM from 1GB to 2GB? Or, are there other ways to make it run faster?
  • 2,878 Answers
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). High CPU levels causes hang ups like freezing. Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM. Uninstall any extras like those pushy toolbars, and add-ons.
Posted on Nov 08, 2012
Have HP Pavilion N5435 with 930MHz freq and ~500MB RAM (can increase to 1GB) Can it support Windows 8 OS?
Does you system meet this criteria: Windows 8: system requirements
  • Processor 1GHz or faster
  • RAM 1GB (32bit) or 2GB (64bit)
  • Hard disk space 16GB (32bit) or 20GB (64bit)
  • Graphics card Microsoft DirectX 9 graphics device or higher
Windows 8: additional requirements
  • To use touch A tablet or a monitor that supports multi-touch
  • To access the Windows Store and to download and run apps An active internet connection and a screen resolution of at least 1024 x 768 pixels
  • To snap apps A display with a resolution of at least 1366 x 768 pixels
Read more: http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/#ixzz2z83szG8E
Apr 17, 2014 | Computers & Internet
How to make my PC run faster?
I would upgrade your ram to at least 1GB of ram or more, "the higher the better" ram memory will make the computer considerabily faster. Plus a Video Graphics Card with one 1GB of ram will free up resources in your computer and increase performance.
Apr 24, 2012 | Microsoft Windows XP Professional SP3 for...
Can the 1 G of Ram be increased to 2 G of ram on a Compacq V3020
The specs for your laptop says that the maximum allowable RAM that it can hold is up to 2gb so yes you can upgrade it.
2 pieces of 1gb RAM (1gb per slot) or a single stick of 2gb on 1 slot.
Good Day.
Jun 29, 2011 | Compaq Presario V3020US (4400 mAh )
Asus M2V890 motherboard supports max 2GB memory per specs. Is there any way to increase this, or am I stuck with 2GB?
2GB is enough for the MB you are using, if there are no more slots on the MB then you cant increase them.....every slot has a MAX limit of RAM card that can be installed, check the MB specification....i guess 1GB per slot is the MAX...so 2 slots...2GB
Nov 18, 2010 | ASUS V2-M2V890 AMD SktAM2 Barebone System...
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
I have a ACEer 5315 model no ICL50 running Windows Vista. To say Vista is **** is an understatement. I want to switch to Windows 7 but guess I will need a lot more RAM for this. Can I upgrade Ram on this...
I recommend that you switch to Windows 7 without upgrading your RAM. Windows 7 is a lot faster, better and uses less RAM than Vista. Recommended RAM for running Windows 7 is 1GB but I have installed them on a Centrino 1.5GHz with 768Mb of RAM and they run perfectly.
So make the upgrade to Windows 7 anyway and if you feel that you need more power then you can get more RAM.
Also, download Windows 7 upgrade advisor to check if your pc is compatible. Download upgrade advisor here.
Feb 06, 2010 | Acer Aspire 5315 Notebook
Ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
Apr 01, 2009 | Computers & Internet
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Laptops
Increasing the RAM does not harm machine it will be faster while accessing multiple applications on the operating system it's very good to have 2GB RAM on a Laptop .Normally u get 1GB RAM on a laptop when u buy
Aug 03, 2008 | Toshiba Satellite A135-S4527 Notebook
Fujitsu FMV lifebook TH40/D Logo
54 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
