Question about Frigidaire Washing Machines
I have a frigidaire front load. not 2 yrs old. wouldnt spin, thought load was to small. put in reg size wash, all that happens is barrel turns a few times then stops. Changed to spin cycle but does same thing. sounds like its making noise then stops like a breaker is tripped does same on all settings..
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
maddogsteve1
  • 18 Answers
SOURCE: shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
Posted on May 25, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
  • 572 Answers
SOURCE: Frigidaire Front loading washer P/N 134465400 0410
remove toe panel and clear the coin trap. its clogged
Posted on Feb 13, 2010
  • 1796 Answers
SOURCE: GE Profile WPRE6100G Top Load Washer My washer is
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 03, 2010
I am looking to buy a used Frigidaire GLWS1233AS2 Top Load Washer and GLER331AS2 . They are supposed to be 3 years old. Are they good machines or do they have lots of problems?
Mine is 10 yrs old and I am just now having a problem. Clothes are too damp after last spin cycle. Hopefully, I'll get an answer here soon. Another problem I noticed a few months after I got it, with this model, is the fabric softener dispenser on top of the agitator. You have to remove it every single time and clean it. I added a little water to it before adding fabric softener and thought that would help to stretch the cleaning to maybe once or twice a week. Don't do it! I started to smell mildew and found out why. The agitator shaft that this dispenser sits on was caked with old fabric softener. I just use the blue Downey ball now. The fabric dispenser stinks but I have had 10 yrs of good washing.
Feb 14, 2013 | Frigidaire GLWS1233A Top Load Washer
My washer sounds like it is pumping water out during teh spin cycle, but the tub is not spinning. I have opened the front and the belt looks good. Any thoughts?
usually the washer pump will remove excess water for a few minutse this happen too most washers i have seenm after a few minutes it should kick into another cycle to spin it.
Nov 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
My frontloader starts out fine , but when time to drain, it spins and only a small amount of water comes out,the spin cycle is so load and moves the washer while spinning also the cycle ends and the...
check water pump , from your discription i beleive you have a blockage before the pump this would account for the small amout of water removal
NEVER OPEN MACHINE CASE WITH REMOVING POWER PLUG FROM THE MAIN POWER SUPPLY
Jan 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer not spinning
Unsrew the bottom panel and u will find the pump to the right disconnect the hose from the back thats coming down from the tub.You will find a pocket behind the hose connect filled with all kinds of change probably enough to buy a pizza and a couple of beers. I also had a old credit card,gas pass bobby pins,hard plastic tags.chains and a hand full of sand.
My Frigidaire frontloader is 9 yrs old was close to buying a new one but this defintly fixed the problem..
works like new again.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Won't spin
Jessi, you need to call for factory service so you wont void the warranty. A couple of things could be going on here. The filter before the drain pump could be clogged with stuff preventing a high spin. Pressure switch wont allow a high spin if it detects water in the tub. The main control and motor control talk to each other and controls the spin. There could be a loose harness or poor connection at one of the boards. I would call for service, it won't cost you a cent...Catriver..post back.
Mar 15, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
