Question about Mitsubishi WD-73827 73" HDTV DLP TV
There is tons of dust how do we clean this area?
  • 1,238 Answers
You need a vacuum cleaner and non-static brush..
Posted on Nov 08, 2012
My purifier says to "perform
Krowan - You will need to remove and clean th efiler on the back, remove and clean the ceramic or glass plaques, as well as clean any dust accumulation inside the uint itself. This cam be accomplished by using canne compressed air with a straw nozzle (like you clean your computer with). Just be sure not to blow dust in your eyes.
The filter you can back flush at the kitchen sink, using warm rater. Allow it to thoroughly dry, before reinstalling it. Th e plaques can be cleaned using unscented ammonia and and old tooth brush. Rinse the thoroughly, place between 2 towel to dry completely, before reinstalling them.
That's about all you need to do. Make sure you reinstall the parts properly and that the filer is triggering the safety device.
To further help you, here's a link to the Owner's Manual, that you can download and print for future reference.
Hope this helped you.
Jun 22, 2011 | Ecoquest Fresh Air Air Purifier
Tip
High efficiency filters come with a cost besides $
Those high efficiency pleated or dust fighter filters will have the 90% or more efficiency in removing particulates, however the CFM or cubic feet per minute of airflow will be greatly reduced, approx 4-500 CFM, and thats worth 1 ton of capacity! So youre 3 ton is a 2 ton now but really clean! On days it seems to be losing the battle with heat remocve the filter for a 99 cent cheapie that flows better, in heat mode they are not as critical in my experience, but summers can be.
on Mar 08, 2012 | Honeywell Heating & Cooling
Hi my lap top turn off alone as is warmer but its cooled
I personally had this model for about a year. It was one of the last laptops to have actual Pentium 4 processors put in it. They create a ton of heat and the heatsink design will clog just like the lint catcher in your dryer. Try this:
1. Take out of the battery and remove the AC Adapter
2. Flip the laptop upside down and locate the two fans towards the back corner.
3. Using an air compressor, shortly shoot air into those fans shooting towards the back of the laptop. (can of air is never strong enough)
4. You should see dust and **** fly out the back.
Note: this is not generally very good for your fans so try not to overkill them. You can keep your laptop in clean areas and even use one of those cooling pads but you will still get dust to stack up inside. I personally did this to my laptop every 2-3 months to keep it clean.
Nov 18, 2009 | Toshiba Satellite A75-S206 Notebook
My printer continues to crumple up the paper! and leave black dust on the edge! I have replaced the cartridge and cleaned out the area behind the rollers that had a TON of black dust. HELP!!
it the leaking toner cartridge would have create tone build up within the fuser. this toner build when hot is just like glue. change the fuser and problem will go away
Nov 03, 2009 | Lexmark E342n Laser Printer
Laptop shuts down
HI- I have one and it shuts down to. For us it was a problem with overheating and dust in the laptop. I beleive there are heat sensors inside the laptop that go, so that could be it. For the most part, when it shuts down, we have found it to be dust as after we clean it, it doesn't happen as much. For the dust- the first time blew air into the fan outlets (both of them) and a ton of dust came out. Sounds simple, but it worked. A tell tale sign may be if your laptop sounds louder than it normally does. We use the compressed air can every so often and even just put the vacum nozle over the fans (you'll hear them whirl and see dust coem out). I also have the lap top sitting on a "vent filter" like people use for thier heting/ac vents (WEB Electrostatic Vent Filters).They come in 4x12 sheets and are cheap. The fans **** up a ton of dust and this helps keep some of it out. Good luck...Steve
Apr 14, 2009 | Toshiba Satellite A75-S229 Notebook
Tv losing color when on then turns off
So far I cleaned a ton of dust caked on all of the components in the back of the tv and then cleaned off the dust on the mirror and lenses.
So far a lot clearer picture and not turning off yet.
Apr 09, 2009 | Hitachi Televison & Video
My dvd rw can not open some of the dvd and dont khnow how do i fix this problem. please guide me.
due to dust and excessive use it happens the lens gets dusty or weak solution is
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now a days service centers are getting tons of them everyday for replacements
pls do rate me FIXYA if i fixed what u wanted
Mar 07, 2009 | Dell Computers & Internet
True Fridge Running Hard
I would try this: unplug unit and use a vacuum cleaner and vacuum out the entire area. Not sure what you mean by "running really hard"? If you mean noisy, then see if you can see source after cleaning. Try this and let me know if I can be of any further help.
Jun 08, 2017 | True 12 cu. ft. / 340 liter Commercial...
Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Oct 28, 2007 | Royal VF1000MX Shredder
Mitsubishi WD-73827 73" HDTV DLP TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
