Question about Uniden Cordless Phone Battery BBTY0457001, BT-446 (CORCPH488B)
Uniden BT-446 Batteries all dying at the same time
Several years ago I bought a Uniden base and several handsets. Now all the batteries on all of the handsets are reading low battery and will only hold a charge for about 10 minutes. Is this a common problem with the BT-446 battery. Will simply replacing the batteries fix the problem, or is there another issue, and would I be wasting my money?
  • Anonymous Feb 03, 2009
    Me, too !
  • 38 Answers
SOURCE: base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Posted on Feb 11, 2008
SOURCE: how to deregister a handset without the base with which it orginally registered
I successfully reset uniden TCX800 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near LCD.
Posted on Feb 24, 2008
SOURCE: Handheld won't communicate with the base
i have the same problem and it has happened infrequently several times. you probably have to deregister the handset and re-register it and rest the base and handheld to communicate since my model is different from yours there may be differences in how to go about it but for my model the suggestion is as follows:
go to www.uniden.com for customer support here is a direct link to some frequentlt asked questions http://www.mycusthelp.com/uniden/supportfaq.asp?sSessionID=&lstFilter_a=&lstFilter_b=&lstFilter_c=&txtCriteria=hanset+won%27t+connect+to+base&optcond=2&iStartCount=1
DCT Series Multi Handset Phone - reset to have base and handsets communicate
Question:
I have a DCT Series Multi Handset phone and one or more of the handsets is not working, what should I do?
Answer:
Try resetting the phone system by using the following steps:
1) Enter the "System Reset" menu, then "Deregister HS" submenu.
2) Press volume/up or down arrow keys to select the handset ID to be de-registered from the list, then press the OK soft key.
3) Press the OK soft key. You will hear a confirmation tone. When de-registration is complete, "Deregistration Complete" appears.
4) After de-registering the handset, move to "Replacing the Base Setting" below. When you go through the deregister procedure if you get "out of range", That is okay. Go ahead and go to the next step.
1) Enter the "System Reset" menu, then "Replacing Base" submenu. "Do you want to replace Base?" appears.
2) Press the OK soft key. You will hear a conformation tone. The base information will be deleted. When replacing the base is complete, "Please Register" appears, register the handset to the new base.
If your handset is reading out of range. Check the the main base and make sure you unit has power. This can be done by placing the handset in the main base to see if the charge in use light comes on.
If your main base isn't getting power please make sure the ac adapter is plugged in and is warm to the touch. If not the ac adapter would be damaged.
To resolve out of range follow the below steps.
Press and hold the end key.
Press and hold the # key.
Release the keys and select replacing base and press select.
You will see Replace base?
Select Yes and press select.
Now place the handset on the base and it should register to the base and allow for calls to be made.
Posted on Jun 28, 2008
SOURCE: UNIDEN Powermax5.8 cordless phone charging
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Jul 30, 2008
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register? In that case you would select that option and select to deregister the handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
Posted on Mar 05, 2009
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
May 19, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
BT Freelance XD8500 - one handset has totally "died". Anything I can do to restore?
just change the battery for new one and you will have miracle...
if memory serve correctly there is two "aaa" batteries in the unit, look how polarity goes!
to test - just insert standard "aaa" batteries and see if unit is resurrected, if so buy re-chargeable batteries, insert and enjoy! check an dswap charger (base) unit, rotate handsets between bases as well, base maybe not charding correctly, check pins on the bottom of the base.
if these do not work - buy new unit, it is not really worth repairing...
hope this will help you solve the problem - do not forget to vote...
Feb 12, 2015 | BT Lands Phones
Uniden cordless handet phones
Probaly cheaper to replace phones
May 18, 2014 | Uniden Lands Phones
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
I have uniden Dect 6.0 dual handset. The second handset will not hold a charge even after several days in the base. The battery indicator says full but will not last long enough to even dial a number. The...
Is the phone under warranty?
You should check that the battery is a genuine Uniden one. (Check them all).
From personal experience - I had the same problem with a phone I bought (supposedly) brand new - though mine would last about 10 minutes. The batteries which came in the box were not genuine Uniden batteries. I had to buy new ones direct from Uniden (to be sure) - and no problems since..
I have since been told that sometimes the original batteries are stolen and replaced with cheap nasty ones - before they even get into the shop.
Same thing can happen with computer software - they make copies from the original cd. Then they just need a vacuum packaging machine to make it look like it has never been used.
Mar 28, 2010 | Uniden DECT 6.0 Cordless Phone ID
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
Base settings 'not available'
Press Play. Keep pressed and switch off at mains. Wait a few seconds. Keep Play pressed and switch on at mains, keeping Play pressed for a few more seconds. Then, register handset with base.
Jun 29, 2008 | British Telecom BT On-Air 1300 Executive...
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
Uniden Win 1200
I had the same problem, but good thing I bought three of them. The first one worked right out of the box, the second one wouldn't come up for about two days and the third one took several days before it would turn itself on. My opinion is that the batteries are really flat from being on the shelf for so long before they are sold and have "memorized" that condition.
I went to the Uniden site and their FAQ don't really address much about this product, wish they would expand it somewhat.
Good luck and keep on trying to charge the batteries.
Jan 24, 2008 | Uniden WIN1200 IP Wireless Phone
Lands Phones Logo
107 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
