Question about Mtd Garden
Engine wont crank with spark plug in
16hp tecumsa engine wont turn over with spark plug in. ive replaced battery starter and selonoid. what could make it have too much compression?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 33 Answers
Check the "shear" pin & replace. Sounds like engine is out of timing. Easy fix
Posted on Nov 01, 2014
  • 608 Answers
Hi Peter, check the valve clearances. There is a decompressor on the camshaft that won't work if the valve clearances are to great or a rocker post is loose. Regards Phil.
Posted on Nov 08, 2012
  • 109 Answers
SOURCE: my 2007 john deere eztrak z225 wont crank even
If i understand you right the little square piece is the solenoid, and it should be replaced if it is making a buzzing noise
Posted on Apr 26, 2009
  • 153 Answers
SOURCE: Allis chalmers b starter problem
Two things come to mind. If the plug base is too deep it could bottom out on the piston, and if the cam/shaft timing is off by a tooth or more it could also cause this problem. Check it out.
Posted on May 14, 2009
  • 57 Answers
SOURCE: 2000 with kohler engine starter wont turn engine over.
Try adjusting the valves. Not an uncommon problem.
Posted on May 15, 2009
SOURCE: engine wont turn over. too much compression.
jtd ride on mower wont start will turn over a little but if i take the sparkplug out it will turn over no problem any ideas please
Posted on Aug 30, 2009
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
I have a 98 chevey truck it rolls over but wont start ive checked timing it ok ive checked spark its ok an ive checkefuel pesher
98 chevy truck ? Rolls over an plays dead ! Crank - no start . The starter cranks the engine but the engine fails to start an run .
Where That Machine
Jan 21, 2018 | Cars & Trucks
My 2000 cadillac deville wont start. I bought a new battery. New alternator and a new ground wire under the hood. My starter was tested and is good. Ive been trying to jump it off andnothing will come on
On your car the crank circuit includes a crank fuse, the theft deterrent relay, the key switch, and the PCM in addition to the starter itself.
All of these components would need to be tested to find the problem.
Feb 15, 2013 | Cadillac Cars & Trucks
Briggs and stratton 16hp stating problem
could be stater draging pulling the battery down
Dec 04, 2011 | Briggs & Stratton Garden
My '97 ford taurus isnt kicking over while tryn to start it up
Anything done to car, or happened recently that might affect this?
If starter fluid doesn't work, and starter is cranking normally (too fast may point to a timing belt broke, too slow may mean battery run down and not producing sufficient spark), there's still a problem in your ignition. Pull a sparkplug or two. After cranking a little they should be wet with gas. Check for compression while a plug is out: hold your finger over plug hole when cranking. You should feel pressure buildup and release over and over as long as cranking.
A properly timed engine needs spark, fuel, and compression to start. Keep reviewing your procedure. Something is not right.
You may want to have the computer scanned for possible trouble codes. Check plug wires for proper routing. Were plugs gapped right?
Nov 30, 2011 | 1997 Ford Taurus
98 dode ram wont crank no spark
May have no spark due to a bad crank sensor, which is responsible for spark when it gets a pulse through the cars' computer.
Apr 24, 2009 | Dodge Ram 1500 Cars & Trucks
2004 Kia Sedona wont start but i can hear starter.
if the starter is revving very slowly it is the battery, charge battery. if not, It can be three things happing. 1 no spark 2 no fuel 3 no crank signal or the car computer is bad- you will need to unplug one of the spark wires and remove the spark plug and put the spark plug in the spark plug wire boot, and touch the spark plug on any metal on the car and have some start the car. donot touch the spark plug itself and see if there is a spark. if spark is bright, then it is not spark plug and wires but if no or spark is not bright, check the spark plug wires by applying a little bit of water on the spark plug wire and take a 12v test light, connect the clap to ground and and have some one to crank the vehicle, touch allover the spark plug wires with the tip of the test light, if you see spark, replace the wires and change the plugs.. they are not good. if spark is present, check for fuel by removing any one of the spark plugs and see if it is wet. if wet fuel pump is ok but if not go look for the fuel pump fuse and relay. is fuse blown, replace, check the relay resistor with a volt meter. it should be around 40 to 80 ohm. if everything is good from this point check the fuel pump itself by disconnecting the connector to the pump and apply 12v and ground using jumper wires or some wires to the fuel pump if you donot hear the pump,replace pump. if you, the crank signal or computer may be the problem
Jan 02, 2009 | 2004 Kia Sedona
PLEASE HELP OUT ON MY AUDI
check the ignition switch first.
then
Check all of the battery terminals and cables and check the wires on the starter/selonoid, start from the battery and follow the cable out and check all conections , clean and tighten them and if it still does it the starter/selonoid is bad and needs replacement...
thanks.
Oct 16, 2008 | 1991 Audi 90
Chevy 1994 S10 Blazer Starting Problems
Check the battery is in good condition..
Aug 20, 2008 | 1994 Chevrolet S-10 Blazer
Driving down highway when engine just stopped. Cranks, has gas, no repairs lately. Toy 4AF carb engine. Has been burning oil for last 50K miles and now has 180K. I guess things to look for are spark on...
Check the fuel pump, fuel filter and if fuel is getting to carb. If is not fuel problem, then is usually distribution, replace sparks and check distributor.
Aug 08, 2008 | Toyota Corolla Cars & Trucks
Garden Logo
180 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
