Question about LG 62SX4D 62" Television
White LED scrolling then click and then the top two LED lights turn red with the first one constantly on and the second one flashing.hey guys we were given a rear projector tv by family friends and they said they were watching it one morning and it just stopped working they said it was a bulb issue and it needed replacing but further research tells me its not. i read in another question it could be C871 problem? something to do with the first filter board.
  • 1,238 Answers
You possibly have a lamp issue but most of the cases like that,,
The capacitor is leak or bulged on top..You have to replace it to fix the problem
Posted on Nov 08, 2012
Stop red light flashing to delete 1 missed call
Hi , First of all, Level 1 Notifications are sent to the smartphone to indicate when important or urgent messages are sent. To disable this or turn off,
Depending on the phone you are using: (the steps below are for Blackberry)
  1. Go to your RingTone Profile setting (the one where you change what kind of ring/vibrate that you want)
  2. Scroll down and click on Advanced
  3. Click into your Ringtone Profile
  4. Click on "Level 1 Messages"
  5. Click on "Repeat Notification" and change it from "LED Flashing" to "none"
  6. (Make sure that you do it for what is called "In Holster" and "Out of Holster")
Hope this helps. On another note; sometime, when you delete a call while the missed call is Bolded... the red light will continue to flash. What happened was, the link between the light and the deleted call has unsynchronized and therefore caused the red light to constantly blink. There is one way to restore it back to normal, but no guaratees.... place another voice call to yourself, (use a landline phone to make the call to your mobile). Let the call complete and have it show up as missed. Go into your missed calls and click on it to change the status to "read". It should restore back to a green flashing light. IF not, you have to either wait 10 mins for it to stop, or pull the battery out to soft reset the device back to normal operation.
Feb 13, 2015 | Lands Phones
Tv wont turn on
old technology, dump it. My work place at the airport just installed a 72" Samsung Ultra High Definition 4K flat television. Easily worth the $6,000 it cost.
Jun 17, 2017 | LG 62SX4D 62" Television
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a sharp LC-42CT2E TV which will not turn on. I have turned the tv off with the switch on the tv and at the socket. When the power is connected the led white light at the front of the tv comes on for...
I have the same model with the same problem.After searching for solution to this problem for months I finally found the fault. One of the speakers was
faulty, you will not believe it but change the speakers and the problem will be fixed. The speaker cable is red/black white/black.
Apr 16, 2011 | Sharp Televison & Video
My device a red blinking light with a dark screen.
The red blinking light can mean a couple of things. First, It could mean that you have a message. If that is not the case, you caould have on the 'LED Coverage Indicator'. The LED Coverage Indicator tells you by having the top light flash eather Green or Red depending on coverage. If you are in a place that has good coverage it wil flash Green but if you have little or no coverage the LED will flash Red. To check if you have this setting enabled, first go to "OPTIONS" on the phone in the full menu. Once there, go to "SCREEN AND KEYBOARD". Click on 'SCREEN AND KEYBOARD" and scroll down will you see the option that says "LED COVERAGE INDICATOR". Click on that and switch it to OFF if it is not already there. Then click the back bottton and click SAVE. That should work. If it doesnt, I would call your phone carrier and ask them.
Feb 19, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Aug 30, 2008 | LG 52SX4D 52" HDTV
Nikon d70 green led stays on
If green LED is blinking constantly when camera is turned on, this is a known problem with D70. Upgrade camera firmware from nikonusa.com website.
May 09, 2008 | Nikon D70s Digital Camera
LG 62SX4D 62" Television Logo
79 people viewed this question
Computer Repairing
Computer Repairing
