Question about Lands Phones
Want to control answering machine volume.
I have a Panasonic 5.8 ghz digital answering system. I cannot figure out how to lower the volume when messages are left. What do I need to do to lower the volume on my answering machine so that when messages are left they will not be overheard by others?
  • wolfewoman Jan 15, 2009
    I have the same problem with a new Panasonic - seems like control of answering machine volume is not optional on most digital phones these days - not just restricted to Panasonic. Shouldn't that be a standard feature? If anyone knows of a model that does have this feature - please post.
3 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: I have a Panasonic 5.8
Welcome to Fixya! There should be a Dial on the Bottom Part of one of the Sides.
Posted on Jan 05, 2009
  • 326 Answers
Using the large navigator key in the middle, it is easy to adjust the volume while talking and listening message.
You just have to remember there are 3 (three!) ringers: one on each handset (each requires you to set the volume to zero) and one on the base that isn't terribly intuitive to silence: you hold down the 'down' volume and then hold it an additional two seconds and that puts it to silent mode. Also the base volume must be set to zero if you don't want the 'Call Screening' (where it plays the incoming caller's message at the last preset volume level) feature active.
for any more detailed help on this issue you can refer the manual as follows
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg5480.html
just click the link and download the manual.
thanks.
Speaker volume not on or working. I can hear talking but no one can hear me answer. And no, the mute button is not on.
This is a very peculiar problem. I think in your model the base unit cannot be used to dial out otherwise I would have suggested you dial out from base unit and check. You could also confirm what happens if you receive a call on your phone rather than dial out. Is your voice still not heard in that situation.
If your model supports calls between handsets then try to check if you can have conversations between handsets.(no dial out).
One option is to reset your phone and re-register all the 5 handsets to base unit.
If you do not have a user manual then you can download a copy from this site and follow the instructions for reset and re-register.
http://service.us.panasonic.com/OPERMANPDF/KXTG7731-MUL.PDF
Aug 07, 2014 | Panasonic KX-TG7731S 1.9 Ghz Digital Dect...
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
I can not find my manuel. How do I turn on the
Adjusting the Ringer Volume
You can choose from four ringer volume settings on the handset (off, low, medium,
and high). With the phone in standby, use the up arrow or the down on the handset to adjust the
ringer volume.
You can find your manual online in PDF format here:
http://www.uniden.com/pdf/TRU9360om.pdf
Apr 20, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
HOW TO CHANGE THE NUMBER OF RINGS BEFORE THE MACHINE ANSWERS?
This is for a 5.8 GHz uniden. Hit "menu/clock" then use volume up and down key to select number of rings and then below "menu/clock" hit "set". That should it.
Apr 18, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Can't find booklet to help me in retrieving messages when I'm away from home
Here is the manual :Operating Instructions
Check page 43 : transfering calls
and answering system from page 36
Apr 15, 2009 | Panasonic DECT 6.0 Expandable Cordless...
SA-AK95 volume control problem
This volume controls is actually what is called an encoder. The control itself needs to be replaced. Figure on $5-$10 for the part plus the local labor rate for the total repair cost.
Dan
May 01, 2008 | Panasonic SC-AK75 Shelf System
"CL" blinking on the display of my answering machine
CL is the clock. Set the time and date on the lower right hand side of answering machine.
Nov 30, 2007 | Vtech 5.8 Ghz Handset Cordless Phone...
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
