Question about Dryers
ELECTRIC DRYER HEATER RESTRING COIL
MODEL LEQ1452KSO
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You cannot re-string to heater coil on that model.Here is the coil to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 08, 2012
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: need a dryer coil restring kit for a GE DSXH43EA1WW
i can get you one but i need a make,model, and serial # of the unit to do so first- dan@ dmftrucker@yahoo.com
Posted on Oct 05, 2009
  • 171 Answers
SOURCE: My series 60 electric dryer is not heating. Heater
check the thermal fuse and make sure you have 220v at the outlet.
Posted on Jul 31, 2010
Frigidaire model #LEQ1452KSO
I have a electric dryer LEQ1452KSO won't heat up...how can I locate the fuses?
Apr 10, 2013 | Dryers
Model pye2300ayw turns on but will not heat . I checked for obstruction and pulled duct off to check but still no heat,
When you pull the duct off and turn the dryer on, do you feel air coming from the back of the dryer?? If you do, that means the blower is working. The most common failure on electric dryers that are no heat is a heater coil or element. These are usually pretty easy to replace. Please make sure before you do any work to the inside of your dryer you unplug it! Before you attempt to diagnose the heater coil, make sure the vent line inside the dryer and at the blower is clear of all debris. This could be the problem. There are instructions on this website to take a dryer apart. There are also instruction to diagnose and replace the heater coil.
Feb 05, 2011 | Maytag PYE2300AY Electric Dryer
I cant get my heating element out
here is a diagram of your machine showing where the heater is and for this model you have to remove the drum to access the heater http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dryer-Parts/Model-FER641FS0/1428/0151200/R0701066/00001?blt=06&prst=&shdMod= here is also the expanded view http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0701066-00001.png on this particular model i have also seen technicians buy a heater kit in which they restring the heater wire around the outter housing sears has the part number 131553900 for the housing included at a whoopin 101 dollars id suggest you contact marconeapplianceparts they are definetly cheaper then sears.IF you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 10, 2010 | Frigidaire FER641FS Electric Dryer
Heater coils stay on overheating unit
the heater coil is touching metal,it's grounding out and it keeps the heater running all the time,or you have a bad thermostat that's not cycling.pull the drum and check that none of the coils are touching metal and read out the thermostats with a meter but i'd go with the heater part number WE11M23.this is 160 bucks,when you call your parts store,give them the model number and ask them for a restring heater kit,it will be alot cheaper if it is the heater,good luck,also on ge's the drum is on a rear bearing so you have to pull up first to remove the drum and the heater assy. is behind the drum
Apr 11, 2010 | GE DBSR453EBWW Electric Dryer
We just replace our ge dryer heating coil and approx 1 month later it blew out again and the dryer does not heat. Also the drum turns but has a loud squeak and the timer knob does not advance. Any...
Hi, Did you get a restring kit for the element or did you get element and housing complete? If you just got the restring kit, the element might have sagged and shorted out. The squeek in the drum could be the rear bearing. You probably seen that on the drum shaft when you replaced the element. The timer problem might be, if you use the auromatic cycle, it will not advance if the element doesn't get hot.
Hope this is sme help.
May 08, 2009 | GE DBXR463EDWW Electric Dryer
No heat from the dryer
if your dryer has a lot od lint buildup inside it, some of that lint will fall onto the heating element in back on th wall and cause a hotspot. To examine your heating element you must gain access to it innards. Open the door to the dryer and remove the screws that are holding down the top first.Raise the top or yank the top out yer way depending on the model (no I didn't look up your model)Next remove the screws holding the front panel on and lift it out yer way. Take the idler loose from the bellt and get the drum out. You will then be able to see the heater.The problem will become almost immediately recognized as a broken heating element. Please keep in mind you can buy a restring kit instead of a complete heater pan and assembly already restrung. Just do not leave large gaps that would cause premature breakage in the coils of the new restring kit. Be sure to get all the junk out the back of the drum before reinstalling it. How difficult is this job? It will take a strong will, detirmination, parts and a 6 pack. Send me the 6 pack. LOL
Apr 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Timer / heater malfunction
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
Jan 17, 2009 | GE DCSR483EA Electric Dryer
Dryer not heating
If it runs then the fuse is not blown so it is most likely a broken element. Start here:
5a3cea6.jpgTIP: you do not need to spend 90 bucks on a heater pan and element you can get a restring kit for 1/3rd the price, Just off the top of my head I would say you need part number 5300622032 restring kit. No more than 25 bucks.
Jan 09, 2009 | Dryers
Kenmore Dryer model # 417.99170120
ummm this is actually a pretty complicated process, definatly more Involved more then other units . the face plate has to be dropped, the control panel will have to be dropped, 10 or so screws across the very top of unit must be removed. th ebeltis the removed and the drum is removed from machine,(lifted off hte rear bearing assy will take a little lifting but itll pop off. youl then see the heater. there are 4 screws on the back of unit that hold ont he heater pan w/ heater assy. youll need to remove theese as well. unless you have a heater in a bag and your gonna restring into existing pan. id make sure ht e heater it definitely bad before pro ceding further, POWER im sure is off. the heater will be physically broken in a spot if no good if not your looking for a bad thermostat stopping heater from operating, anyway then put unit back together in opposite order and your good to go,
Mar 16, 2008 | Kenmore 63942 Dryer
Electric dryer coil overheating after DIY repair
The correct part number that we have on hand (Appliance Parts Warehouse, Sears, etc) is 5300622034.  This would be the correct element restring for this model.  Tried to find the number you have but couldnt.  If its the wrong restring kit, it will do just what its doing.  They make these just the right length for the resistance values.  I know the old GE models you had to measure them just right.  I believe that you probably have the wrong one.  Hope this works for you.  Jim
Oct 24, 2007 | Dryers
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
