Question about Husqvarna Huskylock Computerized 910
I am having trouble with loose stitches and my fabric is not being cut by the blade. I have t Cleaned my machine , rethreaded me serger a few times , I have adjusted the tension , I am traveling and I do not have my Manuel so I do not have my Manuel with me . Thank you for your help , Linda Brown lsb42@att.net
  • Husqvarna Master
  • 7,365 Answers
Try changing the needles
check the blade to see if it's loose or misaligned or dirty
try wiping the blades,, try using silicon spray or alcohol on them
to clean them.
after you check the blade to see if there loose or not,,
lay a single thread across the lower cutter blade and handwalk the needle through a stitch cycle watching that thread across the knife blade. If the thread cuts clean the blades are sharp. If it moves
forward on the blade, the softer blade is probably dull enough that it needs replacing
Posted on Nov 08, 2012
Pushing material away, but still overlocking
It is difficult to tell what exactly is happening with your serger.
First thing--make sure you RAISE the presser foot BEFORE you thread any of the threads. This releases the tension disks so the threads will seat properly. You may need to remove all the threads and rethread from the beginning, making sure you thread each in the proper order. Start out with the thread tensions set at the ideal setting--usually the halfway point between the high & low numbers. From there, you will adjust them to even up the thread tensions.
Are you actually trimming off some of the fabric as it is stitching? If so, you might try increasing the cutting width (moves the cutting edge further toward the right) so that there is more fabric caught within the looper threads. It also appears that the looper tensions may be too loose. Try tightening the upper and lower looper tensions so less of the thread loops don't fall off the fabric's raw edge.
Make It Handmade Understanding Your Serger Features
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Meet Serge Beginners Guide To Using an Overlocker Serger
Using Serger Learn to Use Your Serger to the Max
Bernina 700D Serger 8 Cutting Width Knife Adjustments
Dec 30, 2015 | Sewing Machines
I have a babylock evolve serger. It serges fine w/o the blade engaged. Once I engage the blade, the stitches don't hit the fabric
most Sergers have a blade adjustment that allows you to move the blade closer to the sewing plate as well as further away sounds like yours may be to close to plate. Open the door to the underside of your sewing machine; their should be a round knob at the base of the blade are. Turn the blade until it moves away from the sewing plate. test and see if you have adjusted it enough so as not to cut your stitching off. hope this helps
Jan 11, 2015 | Sewing Machines
Do I have to have the cutting blades on the machine to serge material? Also, what's rolled hem and whats overlock?
No you do not need the cutting blade to serge but you shouldn't have to remove the blade it you should be able to push the knob at base of blade inward or pull it outward to turn blade downward out of the way.
TUTORIAL - How to do a rolled hem on a serger - StitchCraft
http://stitchcraftonline.com/blog/?p=42 - 71k - similar pages Aug 5, 2009 ... One of my favorite uses for my serger is to do rolled hems. A rolled hem is were the machine folds the fabric under a tiny bit and then stitches it.
Jan 05, 2015 | Sewing Machines
I have an elna 664 serger and I am experiencing skipped stitching. I am sewing thicker fabric, so I am assuming this might be the problem, but not sure. I was told it might be my timing but I am not sure...
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. Possible timing problem--need to be checked at a sewing machine shop
May 01, 2014 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Loose stitches and blade is not cutting
you might need a new blade
try tightening the tension one number at a time and
use a scrap piece of fabric to sew on checking the stiches till they look
normal
Nov 08, 2012 | Sewing Machines
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the...
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Oct 30, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
51 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
