Question about Measuring Tools & Sensors
Atech weather station not recieving from external
2 Suggested Answers
SOURCE: atech weather station with
First thing to do is remove all batteries. After you do that, insert the new batteries into your receiver unit. After a few seconds, insert the batteries into first sensor (-> ch 1) After first sensor has connected (beep from receiver) insert the batteries into second sensor. Click on the link below to access the user manual for the WS303G
http://www.atech.hk/
Posted on Oct 19, 2010
31215 Wireless Outdoor Thermometer manual
With mine, the battery in the weather station has to be changed twice as often as the one in the external unit. Even though the display on the home unit is visible, it doesn't have enough power to pick up the signal from the outside sensor.
I am not familiar with yours, mine is national Geographic.
The reviews on yours are very mixed, but lots of questions are answered.
Amazon com Weather Station with Wireless Outdoor Thermometer 31215 Home...
Jul 24, 2016 | Measuring Tools & Sensors
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
I'm looking for operating instructions for a Professional Wireless Weather Station with Outdoor Sensors WH5302
Go on e-Bay, look up weather stations, and send a note to tech support via e-mail to Raul. He seems to care about issues with the DR Tech weather station (I've had many, issues and weather stations!). Rick
Apr 30, 2014 | Measuring Tools & Sensors
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Auriol 4-LD3091 weather station will not pick up sensor
I had the same problem and gave up on the unit for a while, then I had another attempt and found this worked for me. Take the batteries out of both units (receiver and outside sender) then reinsert the batteries BUT put the batteries into the outside sender unit FIRST, this seems to make the difference as when you then put the batteries into the indoor base-station it detects the outside temperature signal immediately as it starts to set itself up .
Aug 18, 2012 | Measuring Tools & Sensors
I have had my radio for a while and now just out of the blue the weather band stopped recieving or something, the rest works fine the wx led even lights up just no audio
If there is static noise, then it's probably not the weather board. We have had something like this happen in our area....
The closest weather station to here up and quit transmitting. The transmitter died after years of use. So all of a sudden there was not weather station. It was out for months.
If there is no noise at all, then there is probably something wrong with the weather board. I don't mess too much with weather boards my self. You could look at the weather channel selection knob and look and make sure all the wires are connected, also the switch to turn on weather.
Nov 10, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Only have a thin line in middle of tv screen. can sometimes bang on the set and recieve a full picture
there will be a loose contact in vertical section of your tv, resolder the legs of vertical ic...with the help of atech person
Apr 10, 2010 | Toshiba 36A40 36" TV
My cb transmits with a very weak signal and won't recieve anything. The weather band recieves with no problems. I couldn't even pick up a signal on my SWR meter but a friend of mine tested it on his home...
There are a few things that could be wrong. If there is something wrong with the mic, you may not hear anything on the radio. but weather will work.
Other then that, the receive section of the radio could be blown.
Try a new mic, and if it doesn't work, then there is something blown in the radio. It needs a tech.
Sep 25, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Measuring Tools & Sensors Logo
52 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
