FixYa.com
Tags:
GE 24 in. Profile PDW7800 Built-in Dishwasher
Top rack dishes have grainy particles on them after... (by 2 users)
posted by Bugsmagoo on May 23, 2007
I have taken out every removable part from the bottom of the dishwasher and cleaned the fine filter, etc and checked for obstruction in the part leading to the pump. It is pumping fine and no water is left standing in the tub upon completing the cycle, but the top rack dishes simply are not getting cleaned or rinsed properly. I don't want to call for service if I can help it. Any thoughts or ideas are appreciated! Thanks!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 09, 2008
Might as well wash by hand because nothing on the top rack is clean. Greasy residue remains on plastic food storage containers and glasses and mugs have residue and food particles left on them. Even the silverware in the bottom sometimes does not get clean. Any suggestions?
Best Solution
posted on Jun 08, 2007
Helpful (85)
appyguy
Rank:Wiz Wiz
Rating: 85%, 114 votes
Run the dishwasher and observe the spray arm,if split it will spray water down: Also check water in tub, is it filling up sufficiently to get near the heater?
If it has a upper spray arm does it spray water?
If not you may have a clogged upper spray arm.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
dishwasher will not drain. ...
standing water in bottom when... Answer This...
GE Profile Dishwasher
Had to unplug dishwasher to... Answer This...
Leaks
My disjwasher leaks during the... Answer This...
Stuck on reset and C3 flashing
My dishwasher is stuck on reset... Answer This...
GE Dishwasher
I ran my dishwasher @ 11:00 a.m... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
