Westinghouse air conditioner model wifxl-60svw2 working for 10 minutes then cutting off. the display will then show FF
bobotfel
  • 236 Answers
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Posted on Jan 04, 2008
  • 54 Answers
SOURCE: ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
Posted on May 30, 2008
SOURCE: Air conditioner blowing hot air alternately
MINES IS DOING THE SAME EXACT THING. LET ME KNOW IF YOU FIGURE OUT WHAT THE PROBLEM IS.
Posted on May 27, 2009
  • 233 Answers
SOURCE: Unit not blowing exhaust!!!
http://safemanuals.com/brand-user-guide-instructions-owner-manual/MAYTAG, this may help you locate the issue. there may have been some degris that is keeping the blower cage from turning, or the cage may be damaged.
Posted on Jul 19, 2009
espressonist
  • 1711 Answers
SOURCE: My Delonghi air conditioner model
The compressor overheating safety switch it off for protection from overheating and result in complete damage of the compressor.
One posible reason is the condenser is full of dust.
Remove the grille and either sweep away or vacuum dust that is readily accesible.
This easy cleaning should be done at least once a year for most efficient operation.
Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly
Posted on Sep 01, 2010
My air conditioner IS AHL 12H1P I HAVE CNNECTED IT .IT START AND DISPLAYS FF OFF WHICH IDONT UNDER STAND AND IT DOES ITS NOT COOLING THE ROOM
The model doesn't ring any bells. What make and what type of air conditioner is it? an FF on the display is telling you something. Either what the machine is trying to do or its a fault code and its telling you whats wrong.
Nov 22, 2017 | Heating & Cooling
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
Ciac air conditioner ff error code
FF code means blown or missing damper fuse. Replace damper fuse (inside equipment cover plate) and try again. If damper fuse blows again, find and fix the problem causing the fuse to blow.
Mar 27, 2014 | Carrier Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
Westinghouse error code FF airaconditioner split
model:WlFXL-36SVW2
error FF what does could be the problem
Sep 14, 2011 | Heating & Cooling
Our cassette air-conditioner, Fujitsu model AU T30RLD is playing up once again. On the Control Panel there are E's displayed flashing where the clock should be visible. I cannot set the clock. When...
Please check your drain pan is blocked. Call repairman to disassemble indoor and remove drain water pump motor for cleaning. And reset it. Now your unit will be o.k.
Dec 29, 2010 | Heating & Cooling
Need manual for a heller portable air conditioner. Model: GUSTY10CO
I have a Heller Gusty10c0 Portable Air Con. When It hasn't been used for a while. I turn it on and it last about 10 minutes then just stops. Then when ever I turn it on it cuts out after about 30 secs to a minute. Can anybody help me please?
Dec 12, 2010 | Heating & Cooling
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Aug 23, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
Heating & Cooling Logo
399 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
