Question about Kitchen Ranges
Oven not working
Tappan Model No. 31-5592-18/01. Heard a noise come from the range. The cleaning control is on but not working and can't turn it off. The oven won't go on. Stove top is working. Tried to turn of power to the unit to reset. Didn't work.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
The control board has gone out in the console. Here is the part you need to order. To replace the part, unplug the unit, remove the back of the control panel. Be sure to take note of the wiring connections.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 10, 2012
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
SOURCE: Amana gas range ARGS7650 oven not working, stove top working
check clock has not accidently been switched to Auto this can also happen if someone has interupted the power supply
Posted on Dec 26, 2007
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
I have a basic tappan oven,,,no extras,,the oven wont heat,,the pilot lights,,,but will not heat up,,,is there somehting i can wiggle or clean out??
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 20, 2011 | Tappan MGF500PBW Gas Kitchen Range
My Tappan oven is built in and 23 years old. I put it on self clean. It did, but the noise won't shut off. I turned the oven to off, but the noise still goes on. There is no way I can unplug it.
go to your homes power panel and find the circuit breaker or fuse controlling this circuit and shut off the breaker or pull the fuse,this will power down the unit
Nov 07, 2010 | Tappan TGF320 Gas Kitchen Range
I am showing the code of F5 on my self cleaning oven and the alarm is sounding
Hello there:
On these tappan ovens the f-5 or even the f-6 & even the f-7 can show up meaning you have a bad electronic controle board that needs to be replaced normally this will cost about 40 dollars for the part
F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control
Jul 14, 2010 | Tappan TGF320 Gas Kitchen Range
I have an older Tappan Centenniel range with a self cleaning oven. I have lost the book and need to know how to clean the oven. It is probably a late 70's model.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Apr 29, 2010 | Tappan TEF242 Electric Kitchen Range
Need Instructions on Self-cleaning for my Tappan Electric Range
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 28, 2010 | Tappan TEF242 Electric Kitchen Range
My Tappan electric range oven wouldnt shut off tonight after baking dinner. Instead, it flashed ''F1'' in the digital screen, and would not allow cancel to work. What could be wrong? It is a Tappan Dual...
The EOC electronic oven control/clock has failed. This is easy to replace. Go to www.appliancehelponline.com and enter your model # for diagrams and illustrations. All parts come with installation instructions.
Apr 09, 2010 | Kitchen Ranges
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
