Question about Chevrolet Vehicle Parts & Accessories
06 Trailblazer has hard 1-2 shift and throwing p0707 code
No prior problems
    Sergeant:
  • Chevrolet Expert
  • 242 Answers
The code Po 707 is TRANSMISSION RANGE SENSOR FAILURE..Any codes from 700 through 998 is transmission and or drive train related..The sensor detects gear selector position and sends a signal to the PCM (POWERTRAIN CONTROL MODULE)...This is located at the driver side lower side of the transmission with a wiring harness going to it it is possible to re-calibrate it which isn't that hard to perform...If you would like to attempt that yourself I can try to explain it...?...But before that you can disconnect negative battery cable which will re-set the computer and erase the code...Sometimes the problem will go away...If you pull the shift lever too fast or have it in a wrong position and try to drive backward while it's in drive then jam it to reverse quickly it will throw.a false fault code at times...So try this and it may solve the problem....check fluid level anyway...I hope this info will help........Brooks/Metalpoet......
Posted on Jun 14, 2014
Trouble code p0422 check engine light on need a map on this part
To look up OBD2 Codes. https://actron.com/code-lookup
Code P0422: Main Catalyst Efficiency Below Threshold Bank.
According to enginecodes.com " "Possible causes - Warm Up Three Way Catalytic converter deterioration or malfunction
- Exhaust system leaks
- Loose front or rear HO2Ss
- Faulty front heater O2 sensor
- O2 sensors harness is open or shorted
- O2 sensors poor electrical connection Code p0707: P0707 Transaxle range switch circuit malfunction (inhibitor switch) open/shorted; low voltage".
According to Ricksfreeautoadvice.com: "Here's how to adjust the switch to get the codes to go away
1) set the parking brake
2 Remove the air filter box assembly so you can access the transmission range switch.
3) Turn the key to the ON position, but do not start the vehicle. Move the shifter to the neutral position.
4) Align the alignment holes between the switch and the shift lever. Insert a 5mm drill bit into the adjustment hole to verify the proper alignment for the neutral position.
5) If the bit won't fit, the switch is out of alignment. Loosen the bolts and move the switch until you can insert the drill bit. Tighten the bolts to 96 INCH/lbs." I hope that helps.
Apr 13, 2015 | 2000 Hyundai Elantra
Explain the code p0707
P0707 Ford - Transmission Range Sensor Circuit Low Input
Read more: http://engine-codes.com/p0707_ford.html#ixzz35T8d8yN8
May 27, 2014 | 2005 Ford Escape XLT
06 hyundai tiburon- where is the shift solenid c located? is it in the transmission or outside?
There is a TSB # 09-AT-018, This causes multiple Check engine light for transmission codes, Inspect this area12_9_2012_6_40_54_am.jpg
Dec 09, 2012 | Cars & Trucks
06 pontiac grand prix shifting hard off a dead stop
If all gears are shifting hard, may have a code p1811 set-trans adapt long shift. When this code sets it commands full line pressure causing hard shifts. Usually the pressure control solenoid is at fault. You need to have it scanned for codes.
Nov 21, 2012 | 2006 Pontiac Grand Prix
Got a 06 trailblazer well drive it revs at 5000 rpm and just baily moves
ON YOUR 06 Trailblazer 1.ckeck your tranmission fluid level 2.make sure its red and not burnt (brownish color) 3.if the service soon light is on check for trouble codes.
Sep 02, 2011 | 2006 Chevrolet Trailblazer
Transmission distance sensor (code P0707) where is this located? My problem is the RMP goes in high, the check transmission comes on, if you put it in park and the light or stop, you can't give it any...
Transmission distance sensor ?????? P0707 Transmission Range Sensor A Circuit Low Input Transmission Control Module - AISIN Transmission REFER to Section 307-01B .
My problem is the RMP goes in high,???? RPM P0707 TR sensor TR sensor circuit low input TR sensor signal is below threshold of 0.127 volts, sensor/circuit electrical malfunction TR sensor indicates a stuck position (D-3rd gear), no adaptive or self learning strategy. Install a new TCM.
Your best bet ,take your vehicle to a ford dealer .
Oct 01, 2017 | 2005 Ford Five Hundred
Where is the shift solenoid located? How do you change one? We had our Trailblazer checked when the "service engine soon" light came on and that was the code that came up. Prior to the light we...
The shift solenoids are located inside the transmission.The average person and alot of mechanics can not even attempt to fix this problem.The transmission needs to come out and pulled apart and repaired.Take it to a specialtiy transmission shop they can tell you.Some vehicle can be repaired that have this problem without tearing the trans out or apart it is best to take this problem to the expertsTrust Me
May 04, 2011 | 2002 Chevrolet TrailBlazer
Shifts rough in 1st gear and lose overdrive at times
on the older style blazers the fan clutches did fail and would often be misdiagnosed as shifting problems as the clutch engaged and disengaged.... also a hard 1-2 shift can be due to your vehicle storing a transmission fault code in the ecm... some transmission fault codes will put the transmission into a fail safe or limp mode in which it engages high line pressure .... this can cause your hard 1-2 shift and will feel normal most of the time other than that. high mileage on the transmission fluid may also require it to be flushed and have the filter kit replaced
Jul 23, 2009 | 2003 Chevrolet TrailBlazer
Vehicle Parts & Accessories Logo
67 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
