Question about Kitchen Ranges
I have a maytag stove flashing F4 what does that mean
  • 4 Answers
F4 relates to the oven temperature sensor
Posted on Nov 08, 2012
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
My maytag flashes the code F1. What does that mean?
I just went through the same thing. According to what I have researched, it means a problem with the touchpad. Found out the clock/touchpad can run up to $200 to replace minus labor. I had nothing to lose so I took the back panel off the stove, took out the unit which is held with 4 screws, and used alcohol on a qtip to clean the circuit board. Mind you the stove is 15 years old and wasn't about to pay 200 dollars for a part. Put it all back together and the error code went away and the oven is now working again. It is getting me through Thanksgiving but I am buying a new stove because I don't know how long this repair will last. You have to consider the age of your range and what you are willing to pay.
Oct 18, 2014 | Maytag Ovens
F4 error
The F4 error means that the oven temperature sensor is giving an open signal. Probably the oven temperature sensor needs to be replaced. However, sometimes, the wiring harness between the sensor and the control unit has a fault or the control unit (computer) is bad.
I hope this helps.
Mar 16, 2013 | Amana 30" Self Cleaning Electric Range...
Stove bbeps and flashes F7
Hi
Thanks for using FixYa. Error F7 on your Maytag means that the keypad is shorted or stuck and to resolve this issue you’ll have to replace the Electronic Range control (ERC).Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 13, 2010 | Maytag Kitchen Ranges
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
STOVE CODE FLASHING
f9 depicts a door lock error
3 specifies the latch lock lower sensor
Mar 01, 2009 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
Sep 20, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
