Question about HP Mini 1000 Netbook
How can I change or fix .lnk file associations on Windows 7?
All my shorcut programs on my desktop turn into lnk files,what should i do?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
This is not an uncommon problem with vista. These lnk files should open the underlying exe file, but if the registry has been altered they will open something else. The following link will take you to a registry fix program that will restore the correct file association for lnk files.
www.winhelponline.com/fileasso/lnkfix_vista.zip
as always read the instructions and make sure that this will work for your version of windows. Not all fixes work for all versions. If you do not have vista or you have other doubts, go to the microsoft forums for your windows version and search for lnk files.
Posted on Nov 08, 2012
3 Suggested Answers
SOURCE: Can't enter my computer & control panel
lawl
Posted on Nov 22, 2008
mytolu10
  • 195 Answers
SOURCE: i can't open any program files they all are in
All you need to to is to repair it or format the system with windows xp
Posted on Jan 09, 2011
My computer programs started to be taken over by windows media program,so I tried to stop this by putting my programs and files accidently into c folder ...8activator.exe.Thats when my problems began,
Wow, I hate to necro an old thread here, but seeing as how there is no answer I will chime in here.
You need to change your file associations. This process varies from one OS version to the next so follow the links below for your respective Windows version. I will include XP since I know plenty of people still cling to that to this day.
I use Windows 10 which does not have Media Center, so I know that walkthrough does not help you. However, it may help others with similar file association issues.
Feb 04, 2015 | Computers & Internet
All my programs open up as a LNK file how do I fix that
Yes, go to one of the files that you KNOW what type of file it is like a xxxxx.PDF. that file opens with adobe then "right click" to open the menu of choices with that file. EXAMPLE "xxxxx.PDF" and select the menu choice "OPEN WITH"
A new menu box will open and you should be able to select the correct program to open the file with, i.e. "ADOBE READER" for the .PDF files. (BE CAREFUL), usually in the bottom left corner of this menu screen there will be a small check box with the question "open all files like this/or type" using this program. If you only use ADOBE for PDF files which you probably do then it's ok. BUT if it is a plain text file or a binary file that has been set to be opened with something else then you have more serious issues to fix.
The same is with MS Word files Power Point ect. select the appropriate program under "open with" to correct the file relationship
Mar 26, 2014 | Microsoft Windows 7 Ultimate, Full Version...
Hi, Dave again - not sure if my problem was visible or not?
you may try to fix it by doing this:
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
If it does not help, reply and I will give you further instructions.
Mar 29, 2013 | Lenovo Computers & Internet
My laptop had been bad for over a year, so, i just fixed it (changed the motherboard actually). Now, the shortcuts on the desktop wont work except i go through program files to open the programs. Do you...
Go to http://www.dougknox.com/xp/file_assoc.htm and download
"LNK (Shortcut) File Association Fix" (Restores Default Shortcut Behavior). Extract the reg and double-click it. (But when extracting, don't put it on your desktop 'cause it won't work!).
I hope it helps
Jun 18, 2011 | Toshiba Computers & Internet
I did something to my pc now all my programs have the extension .ink and i cant run anything or open anything what can i do?
The .ink files are shortcuts. If they have no icon, or the same icon then you deleted the programs. Try reinstalling them. If not, don't worry, just launch you application by double clicking the .ink files. If it doesn't work no worries, that's not a biggie and can be easily fixed in a couple of minutes. There are a couple of ways to do it, read both:
Option 1:
- Go to Start -> "Control Panel" -> Click on Porgrams
- Click on "Default Programs"
- Click on "Associate a file type or protocol with a program." to open the "Set Associations" menu.
- Scroll through the list of extensions to locate the .lnk file extension. The listing will show the description and the current default program associated with it.
- Click on the extension (to select it) and then click on "Change Program."
- Select the program you would like to open *.lnk file types.
- Click on OK.
Option 2 (If Option1 fails):
Simply download following file, unzip it, and run it. It will make necessary changes to the registry. Restart the computer and it should be fine.
http://www.winhelponline.com/fileasso/lnkfix_vista.zip
Jun 17, 2011 | Microsoft Computers & Internet
I don't want Palladium on my computer and I can't delete it
Manual Removal procedure for Palladium Pro The first step you must take in order to remove Palladium Pro is to stop one of the following processes below. Only one of them will be running.
  • Palladium.exe
  • PalladiumPro.exe
  • Palladiumantivirus.exe
  • Z.exe
To Stop this process you can browse to the file location shown below and re-name the file first and then restart your computer. Then browse to that file location again and delete the file.
The next step in Palladium Pro removal is to delete the following file:
Windows XP :
  • C:\Program Files\Palladium Pro\PalladiumPro.exe
  • C:\Documents and Settings\USER NAME\Application Data\Palladium.exe
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Documents and Settings\USER NAME\Application Data\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files\Startup\Palladium Pro.lnk
Windows Vista / Windows 7 :
  • C:\Users\YOUR USER NAME\AppData\Palladium.exe
  • C:\Program Files (x86)\Palladium Pro\PalladiumPro.exe
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Palladium Pro.lnk
  • C:\Users\YOUR USER NAME\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Palladium Pro\Palladium Pro.lnk
  • C:\Program Files (x86)\Startup\Palladium Pro.lnk
  • C:\%AppData%\Z.exe
Once you have successfully deleted these traces, Palladium Pro should no longer be running in your machine and now you should run a complete virus scan for the system using Spyware Doctor with Antivirus. This will let you know whether you have been able to remove all the traces of Palladium Pro successfully and also whether there is any other threat still available in the system.
If you need advanced help or an expert we recommend www.onlinecomputerrepair.org
Palladium Pro Registry Removal Procedures Now that your system is free from the Palladium Pro file traces that have been mentioned above, it is time to get rid of the infected registry items.
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium"
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "Palladium Pro"
  • HKEY_CURRENT_USER\Software\Palladium Pro
It is important that you run a complete virus scan for your computer when you are done with the removal procedure to ensure maximum protection for the system. For that, we suggest you to run the scan with Spyware Doctor with Antivirus.
Palladium Pro Directories: XP
  • UPDATED: We have a report of it being at C:\Windows\Palladium Pro for some users.
Windows 7 / Windows Vista
  • C:\Program Files (x86) \Palladium Pro
Or mail me googolplexcorporation@gmail.com we will remove it through remote desktop support
Jan 27, 2011 | Computers & Internet
Can get on internet! all my programs end in .ink so can't opened anything. when try to download from internet i can but the it comes up windows don't know this extention. then i can't opened. thanks
When double clicking the xp_exe_fix.reg file, windows asks what to use to open it. Go to select from list, then browse and find C:\Windows\regedit.exe, select it and click ok, then double click xp_exe_fix.reg again and it'll ask you if you want to add the info to the registry. Click yes and reboot your computer. You should notice that by going Start->my computer->C:\ and opening any one of the folders, all of the programs appear normal again and will function correctly.If your desktop icons still have the *.lnk extension, run the linkfile_fix.reg by double clicking it, then reboot again. make sure everything seems back to normal and your all done!
the specific locations for the files:
xp.exe.fix
linkfile.fix
Note: if winzip/winrar or whatever isn't working on your machine, either extract the files on another computer or associate the zip files with the appropriate program exe (winzip/winrar) as done for the xp_exe_fix.reg file.
Jun 19, 2010 | Computers & Internet
Ok, well i cant open any program or file except my mozilla foxfire internet from the start menu. on my desktop, all the icons dont show up and all the titles end in .lnk for example: messnger.lnk. when i...
That means your registry is damaged. I would recommend this software to fix it...http://www.glarysoft.com/rr.html If that doesn't work try rolling windows back to a previous date by putting in your restore disk and clicking repair my computer.
Mar 19, 2010 | Compaq Computers & Internet
How do i get rid of total security the bogus anti virus software?
  1. Print out these instructions as we will need to close every window that is open later in the fix. Due to this malware infecting Internet Explorer, it is suggested that you use Firefox or another browser when following these instructions.
  2. Before we can do anything we must first end the Total Security process so that it does not interfere with the cleaning process. To do this we must first download and install a Microsoft program called Process Explorer. Normally, we would have you use the Windows Task Manager, but this rogue will disable the ability to run it. Please download Process Explorer from the following link and save it to your desktop:
    Process Explorer Download Link
  3. You should now have the Procexp.exe file on your desktop. You now need to rename that file to iexplore.exe. To do this, right-click on the Procexp.exe and select Rename. You can now edit the name of the file and should name it to iexplorer.exe. Once it is renamed you should double-click on the file to launch it.
  4. Once the program is running, you should be presented with a screen similar to the one below.
  5. Scroll through the list of running programs until you see a process named tsc.exe. When you see this process, select the tsc.exe process by left-clicking on it once so it becomes highlighted. Then click on the red X button as shown in the image below. Newer versions of this executable may be using names consisting of random numbers or characters. If you see a process that is composed of random numbers or characters and has a shield icon shield-icon.jpg or a padlock icon padlock-icon.jpg next to it, then you have found the process you need to terminate.
  6. When you click on the red X to kill the process, Process Explorer will ask you to confirm if you are sure you want to terminate it as shown in the image below.
    At this point you should press the Yes button in order to kill the process.
  7. Download Malwarebytes' Anti-Malware, or MBAM, from the following location and save it to your desktop:
    Malwarebytes' Anti-Malware Download Link
  8. Once downloaded, close all programs and Windows on your computer, including this one.
  9. Double-click on the icon on your desktop named mbam-setup.exe. This will start the installation of MBAM onto your computer.
  10. When the installation begins, keep following the prompts in order to continue with the installation process. Do not make any changes to default settings and when the program has finished installing, make sure you leave both the Update Malwarebytes' Anti-Malware and Launch Malwarebytes' Anti-Malware checked. Then click on the Finish button.
  11. MBAM will now automatically start and you will see a message stating that you should update the program before performing a scan. As MBAM will automatically update itself after the install, you can press the OK button to close that box and you will now be at the main program as shown below.
  12. On the Scanner tab, make sure the the Perform quick scan option is selected and then click on the Scan button to start scanning your computer for Total Security related files.
  13. MBAM will now start scanning your computer for malware. This process can take quite a while, so we suggest you go and do something else and periodically check on the status of the scan. When MBAM is scanning it will look like the image below.
  14. When the scan is finished a message box will appear as shown in the image below.
    You should click on the OK button to close the message box and continue with the TotalSecurity removal process.
  15. You will now be back at the main Scanner screen. At this point you should click on the Show Results button.
  16. A screen displaying all the malware that the program found will be shown as seen in the image below. Please note that the infections found may be different than what is shown in the image.
    You should now click on the Remove Selected button to remove all the listed malware. MBAM will now delete all of the files and registry keys and add them to the programs quarantine. When removing the files, MBAM may require a reboot in order to remove some of them. If it displays a message stating that it needs to reboot, please allow it to do so. Once your computer has rebooted, and you are logged in, please continue with the rest of the steps.
  17. When MBAM has finished removing the malware, it will open the scan log and display it in Notepad. Review the log as desired, and then close the Notepad window.
  18. You can now exit the MBAM program.
Your computer should now be free of the TotalSecurity program. If your current anti-virus solution let this infection through, you may want to consider purchasing the PRO version of Malwarebytes' Anti-Malware to protect against these types of threats in the future.
If you are still having problems with your computer after completing these instructions, then please follow the steps outlined in the topic linked below:
Preparation Guide For Use Before Posting A Hijackthis Log
Associated Total Security Files:
c:\Program Files\TSC
c:\Program Files\TSC\tsc.exe
c:\Program Files\TSC\Sc2C21UvvM.exe
c:\WINDOWS\system32\winsource.dll
%UserProfile%\Application Data\Microsoft\Internet Explorer\Quick Launch\TSC.lnk
%UserProfile%\Desktop\TSC.lnk
%UserProfile%\Start Menu\TSC
%UserProfile%\Start Menu\TSC\Help.lnk
%UserProfile%\Start Menu\TSC\Registration.lnk
%UserProfile%\Start Menu\TSC\TSC.lnk
c:\Program Files\Common Files\System\Uninstall
c:\Program Files\Common Files\System\Uninstall\Uninstall TSC.lnk
Associated Total Security Windows Registry Information:
HKEY_CURRENT_USER\Software\1FD92E3F7C34799BFB075C41DA05D1FE
HKEY_CLASSES_ROOT\CLSID\{D263FA6D-84CC-48A8-9AF6-C664362B7A5B}
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D263FA6D-84CC-48A8-9AF6-C664362B7A5B}
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run "1FD92E3F7C34799BFB075C41DA05D1FE"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center "AntiVirusOverride" = "1"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Security Center "FirewallOverride" = "1"
Sep 29, 2009 | Microsoft Windows Vista Home Premium with...
HP Mini 1000  Netbook Logo
144 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
