My Sony LCD model no CX52 There r white patches and background images are not visible Screen is full of pathes what to do
The LCD television is a flat-panel television which utilizes a Liquid Crystal Display technology. It has two layers of glass which are polarized and stuck together. The liquid crystals are held in one of the layers. These liquid crystals pass, or block the light, to produce images on the screen when the electric current passes through it.
However, the crystals do not produce their own light. The light comes from the series of fluorescent lamps at the back of the screen. There are millions of shutters arranged in a grid, which open and close to release and trap some of the light that is not needed to create images. Then each shutter is paired with a colored filter which produces a sub-pixel. These are so small, that when they combine, they create a single pixel, which appears to be a single spot of color on the screen. With the help of the fluorescent lamps, the images created by the liquid crystals become visible to the viewer.
LCD television produces high image quality. They can be made very thin, which makes them less space-consuming, and the user can hang them anywhere. This makes them appealing to buyers.
LED TV's are actually very much like LCD TV's. They also have a flat-screen which utilizes Liquid Crystal Display technology. The only difference is their source of light, which is at the back of the screen. The LCD TV uses fluorescent lamps, and the LED TV uses LED (Light Emitting Diodes).
There are two types of LED backlighting. One is referred to as Edge lighting, and the other is called Full-Array lighting. With the Edge lighting, the series of diodes are arranged along the outside edges of the screen. When there is power, the light is distributed across the screen. Alternatively, in Full-Array lighting, there are several rows of diodes behind the entire surface of the screen. They provide more control over brightness and dimming, because the diodes can be turned on and off independently.
LED TV's are LCD TV's with a new backlight system. They are newly developed for LCD's, because Light Emitting Diodes are said to give more balance in color saturation, and use less power than the fluorescent lamps. LED TV's are the newest version, and that's why they are currently more expensive than the standard LCD TV's.
Summary:
LED TV's are still LCD TV's. They are just considered to be the newer LCD TV version because of the new backlight system used. The LED TV uses Light Emitting Diodes, while the standard LCD TV uses fluorescent lamps. Although they both still use Liquid Crystal Display technology. The main difference is the part behind their screen, which is the backlight.
Read more: Difference Between LCD and LED Televisions ' Difference Between ' LCD vs LED Televisions http://www.differencebetween.net/object/difference-between-lcd-and-led-televisions/#ixzz2Bb0rIue6
Posted on Nov 08, 2012
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
SOURCE: hisense[gva] modelPDP421 plasma
You most likely have image burn in on the display if it is not in a straight line. If it is in a straight line than it can be dead pixels. It is most likely the first issue I saw this same issue at work with an HP plasma TV.
Posted on May 10, 2008
  • 192 Answers
SOURCE: Flickering dots
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Posted on Jun 03, 2007
  • 225 Answers
SOURCE: Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Posted on Nov 14, 2008
  • 175 Answers
SOURCE: Purple blotch on screen
hi..This patch can be a result of your TV 's Auto Degaussing
Coil problem. Metallic parts of a TV gets magnetized and the
ADG coil demagnetizes them. At power on you should hear a
sound,which is the ADG coil.please check the ADG coil connector
it might have been pulled out. The ADG coil is wrapped around securely
on your TV's Picture tube and power is tapped directly from the AC
Main via a plug in type connector to the TV main circuit board.
check it out..
thank u..
rate me..
Posted on May 04, 2009
I got some white patches appeared on my led which is very visible in black back ground which is awful my product is sony vaio E series laptop can any one tell me why does those spots appeared
That's called backlight bleed. It's a known issue with certain models of the LED screens. I had a similar issue with my previous laptop, a Lenovo G560. The only solution is to replace the screen.
Nov 18, 2013 | Sony VAIO E Series VPCEB36GX/BJ Notebook
I have same sony model, I have problem with vertical lines on LCD Screen, When i power recyle and switch on the TV, i can see the clear image , After on mintue and half the image fade and i can not see...
Unless you are really good in TV electronics, there is really no simple solution...the transformer for the video screen is heating and shorting out. I hope you have a warantee or guarantee on it!
Dec 02, 2012 | Sony 46 KDL46EX520 LCD TV
Black shodows on screen. Visible w/ every source...less visible with bright background...very visible with medium to dark blue background. Have seen a lot of complaints on the Internet related to this...
This problems only two posibilities,one some how u got a light image burn in into the LCD screen panel itself.If it is the LCD screen burn in,this is not repairable.The other one it could be the T-Con decoders board problems and it dying this board sit wright at middle at the bottom of the LCD screen panel to decodes and regulate pictures as it passing and go in and out of the LCD screen panel itself.Tries websites like Shopjimmmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement,possibilites could solved ur light background shadows problems.
Dec 07, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Kodak Easyshare C763 White-out of outdoor pictures
Is this also apearing on the printouts or only on the LCD?
In any case if this is a constant occurance and in all SCN and dif. lightings I believe this is a repair.
If OoW the cost is aprox. 45 pounds + shipping to the repair centre.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 29, 2009 | Kodak EasyShare C763 Digital Camera
Hisense[gva] modelPDP421 plasma
May 10, 2008 | Hisense TA42P40M 42 in. Plasma Television
Laptop's LCD Panel showing a vertical burn-in patch (Picture Attached)
Try updating your display driver.
Generally the computer should be updated as far as the drivers is concerned.
Check on line at the website of this laptop for updated drivers.
Check these before you do anything else.
Jan 31, 2008 | Acer TravelMate 2300 Notebook
Solution
if it affects all inputs including the MENU or OSD on tv .There is a good possiblity your set need a whole new LCD panel .The panel comes withe digital board that when going bad will display weird images on screen.It is not available on its own .It only comes with new LCD panel.If it affects only certain inputs then you have a (B) board bad on tv .So tv might need service in the furture..
Nov 26, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Mar 22, 2006 | Sony Handycam CCD-TRV318 Camcorder
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
Electro Med Services...
