Samsung 52" ln52a650a1fxza Turns on and backlight goes off after 10 seconds
TV turns on and then after 10 seconds the backlight goes off. If I turn the TV back on, the backlight goes off quicker than before. I've replaced all the capacitors on the power supply board with no change.
  • 2 more comments
  • John W Nov 08, 2012
    Bad inverter? or bad lamp somewhere?
  • John W Nov 15, 2012
    Replaced the inverters and was able to get the set to now stay powered on. If the brightness of a picture is too bright, it will flicker and eventually the backlight will go off. I was able to turn down the backlight and brightness in the settings and it stays on, but it's too dark. Also, AV1 and AV2 don't work, only the cable input works.
    I can see what appears to be a faint darker line near the bottom. I think I have a bad bulb in this unit. The bulb transformer near that section does make a huming noise. Should I remove the transformer and do the jumper trick?
  • John W Feb 15, 2013
    It was a bad bulb. Found a replacement bulb online, replaced it and now it works fine. Was a real pain though to get inside the panel. Had to take the whole TV apart!
3 Suggested Answers
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Ln52a650a1fxza keeps powering on, off,on etc caps looked good, but, replaced anyway-- checked diodes all ok outputs on cn801 all ok same problem persist Any suggestions thanks
this is a problem with this model with a manufacturing date between:2/2007 and 4/2008 and that it was related to a faulty batch of capacitors.Samsung have been extending warranties for some customers to save face a little, have a look here for more info:
Samsung TV Keeps turning off and on Forums CNET
Feb 09, 2016 | Televison & Video
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Tv turns on for a few seconds then goes dark but still have audio. Picture is barely visible if you stare at and concentrate
Most likely your backlight inverter is defective. On a set this big, the inverters should be seperate boards. It could also be leaky caps in the power supply, or a defective mainboard that isn't holding the "BL ON" signal. The tv is repairable but most repair shops will want to gouge you on price.
Sep 21, 2011 | Samsung LNT5265F 52 in. LCD HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
