Question about Fisher and Paykel Washing Machines
My Fisher and Paykel MW058 top loader wont fill up as fast as it use to
When I do a cold wash it seems to take forever to fill no matter what level I use. I have been able to lift the lid just enough to see that the water is just dribbling in to the machine.
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
Turn off the water and remove the inlet hose at the machine. There is a filter screen there and it may be plugged up.
Posted on Nov 09, 2012
  • 1 more comment
  • Phill Watts Nov 12, 2012
    Thanks for the reply. Sorry but did not fix the problem.
  • Richard Roth
    Richard Roth Nov 12, 2012
    You will need to replace the valve.
    The value? Sorry I am not a technician and Fisher & Paykel want $129 + the cost of parts so I am trying to save a dollar.
5 Suggested Answers
  • 58 Answers
SOURCE: Water flow into machine dribbling - Fisher and Paykel GW712 (AU)
The first thing that needs to be done is to disconnect the fill hoses from the back of the machine. Once disconnected, look at the inlet valve screens and check for blockage, if clear, open the water valves and check for water flow through hoses, if not clear, clean screens at fill valve, reconnect hoses & check for operation. If the problem remains, then the problem is with the machines fill valve & it would need to be replaced
Posted on May 01, 2009
  • 3 Answers
SOURCE: Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Posted on Feb 20, 2010
dcramer531
  • 1654 Answers
SOURCE: Hoover 550M washing machine - taking ages to fill,
Check the inlet screen on the hose connection on the back of the machine. This may be clogged with debris, also make sure you hose is not crimped. You can unhook the inlet hose and put it in a bucket and turn it on to see how much water is actuall coming thru that hose. I suspect some type of blockage in the inlet.
Posted on Nov 11, 2010
  • 4 Answers
SOURCE: Whats a code 43 on
That's an 'out of balance' switch problem. Typically caused by a crook microswitch that lives under the main processor housing. Can replace with a generic switch from Jaycar or similar if needed.
Posted on Feb 26, 2011
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Dec 05, 2014 | Fisher and Paykel Washing Machines
Iw810au won't stop filling
water level pressure switch tube is probably blocked with soap etc. or the pressure switch has failed (much less common)
Aug 02, 2014 | Fisher and Paykel Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
May 20, 2011 | Fisher and Paykel Washing Machines
Washing Machines Logo
120 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
