Question about KitchenAid KSSP48QMS Side by Side Refrigerator
REFRIGERATOR SIDE-BY-SIDE IS FREEZING UP ALL THE TIME
I'M HAVING A FREEZING UP PROBLEM WITH MY SIDE-BY-SIDE (FREEZER SIDE) THAT IS ALWAY FREEZING UP. I HAVE ENOUGH CLEARANCE FOR GREAT AIR FLOW AND THE COILS ARE CLEAN. I JUST ABOUT CHECK EVERYTHING I CAN TO RESOLVE THIS PROBLEM BUT I CAN'T FIND WHAT IT COULD BE. I HAVE A G.E. FRIG WITH THE MODEL NUMBER OF GSS201EMB (WHICH I CAN'T SEEM TO FIND NO REFERENCE ON) WHAT CAN I DO?
  • hunter mike Mar 08, 2008
    I have a GE refrigerator and the same thing is happening to me. I have taken the duct work off the inside of the freezer compartment and thawed out the coils but about 3 weeks later its froze up again? checked out the fan and its running fine and the door seal is ok I even left the ice maker off to make sure the moisture isn't comming from there.
Could be low on refrigerant
Posted on Oct 31, 2007
I have a westpoint tropical WRK1802g.1 the freezer always freezes but the fridge side stops working at times and then water runs out from the buttom of the fridge side
If you also have ice buildup in the freezer your temps are not as low as what they should be and your refrig compartment will be warm.
Jul 19, 2015 | Refrigerators
Ge profile fridge model PSC 25MSW/PCF 25 MG W PSH25MGW freezer works fone but fridge too warm.
Check to see if you can see any ice building up in the damper between the frig and freezer.
Oct 23, 2014 | Refrigerators
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
I have a Kenmore side-by-side refrigerator model 58647. It runs for a long time and then when it does turn off the freezer gets warm before turning back on again. It also seems to be noiser than it used...
its trying to defrost automaticly. check the settings turn off any defrost settings. i always unplug untill all ice is gone. if it still acts the same way you need to have it filled with free on
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jul 06, 2011 | Kenmore 53642 / 53644 Side by Side...
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
Refrigerator is freezing my produce items (veggies&fruits) Freezer side is thawing and ice is melting waterfalls over and down all other levels. Freezer & frig. settings have always been set on...
heatman101
Dec 10, 2010 | Kenmore 25.1 cu. ft. Side-By-Side...
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
Freezer working but not colder enough to freeze.
It will usually take 24 hours for the fridge/freezer to adjust fully to the temperature settings.
It is also possible that the defrost timer cycle was going into or just coming out of the defrost cycle, thus it could have delayed the start of the cooling cycle, so give it a little time to determine if the freezer is working.
If, not freezing after 24 hours, let us know and we'll go from there.
It takes longer for an empty freezer to get and hold temperatures, so it is always a good idea to have the freezer loaded with bread (thirft store bargains are cheap) or jugs of 3/4 full water (water takes longer to freeze than bread thou).
Hope you find this very helpful and best regards!
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
KitchenAid KSSP48QMS Side by Side Refrigerator Logo
270 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
