Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
GAS LEAKING THROUGH KNOBS, I'D LIKE TO REPAIR IT MYSELF
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
Which valve is it leaking through?
Posted on Nov 10, 2012
I need to replace a gasket on a Richelieu gas fireplace
while it looks easy, the danger from gas is greater than electricity and that is why gas is not in the diy domain
gas affects most gaskets and requires a special material and gasket goo
be safe--- call a gas fitter
May 25, 2017 | Cars & Trucks
Got a P0456 engine code. Also leaking about 1/2 cup water overnight under the engine area.
You have to smoke test the evap system & use a scan tool
& follow trouble charts to diagnose
That has to be done by a repair shop--- otherwise you just throwing
parts at it
Nov 30, 2012 | 2002 Dodge Intrepid
I have a Behringer PMP5000, after a gig, I accidentlly plugged the outputs from an external power amp, into the monitor sends and powered up the unit. After I realized what I did, I powered down, corrected...
Yes, you blew out components associated with the monitor sends. There are several components including an RF bypass to ground and the driver IC, IC8 and a decoupling electrolytic cap. The repair is going to be extensive as it is likely you will have to remove ALL the panel knobs and screws to free up the circuit board for repair. I have worked on several mixers and have three of the PMP5000's myself and dread removing the main board. I am going to suggest something you might consider: Many of the PMP's fail either in their power supply or one of the amps. Due to the repair cost I would consider getting a scrap PMP with this problem and swapping out the panelboard for yours. Often you can get one with blown supply or power amp for around $200 and I suspect a repair shop is going to charge at least that to repair your unit... Then you will have a spare parts bucket as well.
Oct 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
We have an old O'Keefe and Merritt stove in a
on most stoves where gas line connects around back should be a gas shut off valve if none put one on
Jun 06, 2017 | Kitchen Ranges
I have a gas stove top but today all four spark igniters started sparking all at once an now won't turn off even when all knobs are in the off position
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 14, 2011 | Kitchen Ranges
Grill worked fine for almost a year but I recently used charcoal following the directions in the manual (and it worked great). However since using it (& it is long gone), if I turn grill on high,...
Kathleen, the ash and debris left from the charcoal clogged the burners and caused the flames to shoot back thru the venturi valves, which is causing the flames to reach the control knobs. For the most part. I would suspect that the control panel, the electronic ignition, control knobs, the gas manifold for the burners and the burners are now completely shot.
Now, you're at the stage of determining is it worth it, to replace all the parts (if you can find them) and repair the grill. Since you didn't mention who the manufacturer of the grill is and how long you've had it. I have no way to tell how much it's worth. But, if it were me, and the grill is at least 5 years old and it originally cost $600.00 or less, I'd seriously consider replacing the gas grill with a new one. And if you want to do some charcoal grilling, get a separate inexpensive charcoal grill and take good care of it. During the weekday evenings when you don;t have time for charcoal grill to preheat, use the gas grill. On weekends, use the charcoal grill if you like.
Hope this helped answer your question and ultimately help you make the right decision.
Apr 26, 2011 | Vidalia Grilling
Trans fluid leaking from line going into radiator can I fix this myself
most of them are hoses clamped on if is yes easy to repair, unclamp hose on both ends replace with new hose & clamps
Feb 04, 2010 | 2000 Chrysler 300M
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
47 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
