Question about Vizio Televison & Video
I have a E321 VL that suddenly lost audio and video. When I turn it off then back on it says no signal and indicates that it is on channel 80. I bought it approximately 6 weeks ago.
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Frankly if the set is that new take it back for exchange or repair--it should be under warranty.
Posted on Nov 08, 2012
  • 59 Answers
SOURCE: pioneer 60"hd plasama wallmount
If you have H/D one of your cables might be loose i would suspect the red one
Posted on Oct 22, 2007
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
  • 17 Answers
SOURCE: My Sony LCD HDTV, 60
Try this...... Remove the front panel to access the bulb. There are 2 screws on either side of the tv right behind the screen. You may be able to remove them with just your hands. It will make sense when you see them. Once they are loose the panel will pop off. There are 2 magnets that help hold it on, so just pull gently. In the middle you'll see a another scew that you need to loosen. Slide the bar off, remove the cover and you'll see the black box that holds your bulb. There is an allen screw on the left side that will need to be loosened. Once that is loose, the whole unit slides out. Is the top of the vent screen really dirty? If it is, flip it over and try dusting it off with a soft brush, maybe a tooth brush. Try to keep most of the dust out of the bulb itself though, just be gentle. Pop it back in with the reverse order.......
Posted on Feb 03, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
brownline45
  • 310 Answers
SOURCE: No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Posted on Jul 02, 2010
I have lost TG4 & RTE 1 & RTE -how do i restore
Sounds like you have a problem with the aerial or the connection cable. Hows the signal level and quality on the other channels? You need about 80% quality and 50-80% signal level for a decent stable picture. Quality is by far the most important.
Oct 16, 2014 | Humax Televison & Video
My break lights and horn don,t work anymore just went out all of a sudden
Did you check the system fuses? The fuse box is located behind the left side crankcase cover aft of the coolant reservior.
The 15 amp Signal fuse protects the coolant temperature light, the turn signal indicator light, the neutral indicator light, the oil pressure light, horn, brake/taillight, postition light and turn signal light. Basically, if this fuse is blown, your cluster will be inop.
Please let me know if this is helpful.
Oct 20, 2010 | 2003 Suzuki VL 800 Volusia
2003 Suzuki VL 800 speedo cluster, signals, brake light won't work. Worked on the way to work this A.M. Checked the two fuses under seat. ?
Did you also check the system fuses? The fuse box is located behind the left side crankcase cover above the coolant reservior.
Jul 21, 2010 | 2002 Suzuki VL 800 Volusia
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My Panasonic DLP television suddenly lost picture, went to snow and lost audio. What is wrong?
If you have snow that means you've either lost the signal source (cable satelite antenna) or the TV tuner is bad or your not on a recievable channel. Try hooking a signal to one of the video inputs of the TV.
More info on what you have hooked to the TV would help.
Sep 27, 2009 | Panasonic Televison & Video
Problem with printer all buttons flashing
All lights flashing is an error indication. to learn the problem you'll need a service manaual. The procedure is to hit the Continue button twice - see which lights flash (secondary code) and consult the manual. Then repeat that step and look up the final code (tertiary code) in the manual. This should be the problem.
Aug 05, 2008 | Lexmark E321 Laser Printer
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Aug 26, 2007 | Denon DVD-3910 DVD Player
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Open Questions:
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
