Question about Pramac 5000 Watt Generator
Only 1 plug on generator is working
They were just both working and now one stopped. it is snowing now could that have anything to do with it
The blower stopped running during use. Could it be something like spark plugs? I don't see anything in the manual about replacing spark plugs. model 932 027
Not enough information. What kind of blower?, Leaf, snow? Does it use gasoline? What brand is it? This information is needed to look it up. The model number you supplied returned no results.
Jan 22, 2017 | Garden
Where is the spark plug 305 cc 30 inch snowblower yardork
Look for the spark plug wire which usually comes out from the recoil shoud and follow it to the spark plug
Feb 16, 2015 | Briggs & Stratton Snowblower Snow Blower...
Electric snow blower stopped working
Maybe it needs to be plugged into a wall outlet
Feb 16, 2014 | Craftsman 21" 179cc* Single-Stage...
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Honda hs55 slow moving auger stops in snow
Refer to my other comments that I made regarding your snow blower.
Dec 03, 2013 | Honda Piston Rings Snow Blower Lawn Mower...
Sequall 2100 will not start
Change the coil at the magneto that generates the high voltage to the spark plug
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
The AC Plugs on my EU 3000 Generator are not working all of a sudden... I was using it and one plug and it stopped working, so I switched to the other outlet and after a while it stopped working also.
if no power on the plugs check for the cercuit breaker fuses and check for your load why it is tripping the circuit breaker the unit sbould not be overloaded
Jul 07, 2012 | Honda 3000 Watt Portable Generator
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
Generator not generating
you do not need a manual as long as u comunicate with me...
1- check your wireing...anything cutt off reconnect it..
2- check brushes...if broke or anything...replacem...
3- check AVR card...if blown out replace it....
4- if 1,2 and 3 didn't work contact me,...
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Oct 16, 2009 | Electrical Supplies
I have a brushless Genpower 5250 generator, it still fires up fine, but creates no voltage. As a gift we were given a 5600 Sears generator yesterday, and when i plugged in the plug for the pump to test it...
It's very possible that the cord is bad (shorted) causing a fault on the generator. I don't think it's fried or anything. Probably just tripped something. Give it a good look over.
Jul 10, 2009 | Electrical Supplies
Pramac 5000 Watt  Generator Logo
16 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Dinesh Nagal
Level 1 Expert
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
