Question about Danby Kegerator
Danby Kegerator Not Cooling
The unit it about two and a half years old. Plugged it in and the compressor kicks right on but after leaving it plugged in overnight, it never cooled at all. The LED buttons are on and the temp arrows seem to work, but it does not cool off. I hear the fan running inside but the panel across the back of the kegerator is not cool either obviously. Any thoughts or advice is greatly appreciated.
2 Suggested Answers
  • 4 Answers
SOURCE: Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Posted on Nov 08, 2012
TDD 2 Kegerator clicking and not cooling?
It's extremely rare that the compressor will be any good. Usually replacing the start relay does nothing on these small units. If you know how to use a multi-meter and are any good at wiring the cheapest way to go is to get what is called a 3-in-1 start kit at a HVAC wholesaler. You need to know the model of the compressor and/or the horsepower to get the right one. I would recommend getting a service tech to look it over though. Most likely the compressor is locked up.
Nov 16, 2012 | True Direct Draw Systems: Kegerator TDD-2
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Have not used the kegerator for several years. Plugged it in and it immediately started getting cold. Then I unplugged it to move it and when I plugged it back in it does not get cold.
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
Apr 30, 2010 | Beverage-Air Kegerator - Beer Keg Cooler...
My kegerator is not cooling and when i start the unit the pressures dont change is the compressor out or is there a chance the cap tube or dryer is plugged
Good day,
If the pressures don't change, and you can feel the compressor running, then the valves failed in the compressor.
But make sure the compressor is getting power, and the start components mounted on the side of the compressor are working. (overload protecter, Start relay and capacitor if it uses one) An appliance parts house usually can check these components.
P.S. make sure the gauges are connected properly and not cross bleeding.
Feb 26, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Jul 02, 2009 | Danby DAC5020 Air Conditioner
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
There's a loud humming in my danby kegerator after about 25 minutes of being plugged in. Everything was fine for about 2 months. The model number is DKC645BLS. Any ideas would be welcome.
Maybe a locked up compressor...is it cooling at all?
check your owner manual but it should have a 5 year sealed system warranty..
Apr 04, 2008 | Refrigerators
Danby Kegerator Logo
61 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
