Question about Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ
Afmial washer makes a loud squeeling sound all the time
    Master:
  • 545 Answers
The squeal is most likely the belt. check that it is in place and not coming loose or stretching out. The other culprits could be the water pump, the bearing to the drum, or the motor, in that order of likelihood.
Posted on Nov 08, 2012
My son had his front brakes changed Nov 2012, on his 2004 Chevy Colorado. Recently, they started squeeling LOUDLY when pressed. Took it back to mechanic that changed them and they said they were dry. They...
I use powder you know like a baby powder and thst works great to make the sound go away.
but i see that the last time he had them change was in 2012???? that's five years ago!!! either he never drives it or you made a typo.
if its only the sound try baby powder not to much just a bit on the rotters.
if it has been five years ago since he change them he need to change them like yesterday!
brake pads don't get dry by the way!
Sep 29, 2017 | 2004 Chevrolet Colorado
Front end squeeling noise on 2007 honda accord
could be the power steering pump itself. If it has a bad bearing it will do that. Especially when you turn it makes the steering pump work a lot harder.
Aug 31, 2017 | 2007 Honda Accord Sedan
Loud squeeling noise. Sounds like a bearing.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
Hi our F&P iw810 washing machine makes a loud squeeling noise at the start of the wash cycle. What is it? (no belts or gearbox)
sounds like tub bearing or stator is cracked it also can be the clutch between the two tubs check for any hoses or wires touching the rotor its worth fixing as its a very goog model you have
Aug 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My washer make noise to loud when It spin mode. how to fix it
what does the noise sound like is it a high pitch squeeling noise or grinding. need more info
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Fills and drains but it makes a loud squeeling noise when it try to aggitate
does it spin ? if it spins sounds like you have in internal transmission problem to replace it would be roughly 1/3 cost of the machine
Dec 01, 2009 | Kenmore 22422 Top Load Washer
Makes a loud squeel when stopping after spin
sounds like a dry brake check for water damage
Nov 11, 2009 | Maytag PAV2300 Top Load Washer
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
you need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Dec 20, 2008 | Maytag MAV8600 Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Admiral 3.4 cu. ft. Top Load Washer in White ATW4675YQ Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
