Question about Toshiba 62HM195 62 in. HDTV DLP TV
Are there any diagrams of the pcb locations and the location of the remote sensor?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
The remote sensor will be covered in a service manual if you can find one but is always located on the front of the set--clear or plastic lens that usually can be seen----most models it will either be alone or on a tiny pc board up front--see typical one:
Posted on Nov 08, 2012
The tv does 't respond to the remote control
Keep your mobile camera on. Remote sensor face to camera and press any switch from remote. If you get light from remote sensor in camera that mins remote is ok but problem with LED remote sensor PCB
Jan 27, 2016 | Sharp LC46LE830U - LC 46LE830U - 46 Aquos...
Samsung ir sensor
Infrared sensor can be located, just behind the infrared sensor window, at the front panel of the TV. You have to open the TV, and take out the front panel PCB, to reach and reparable this component.
The component will look somewhat like these.
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 11, 2014 | Televison & Video
Remote not work
If remote control is alright, the problem should be with the remote sensor inisde the TV. This is a three solder terminal component, can be located just behind the infrared sensor window at the front panel of the TV. You should have to open the TV, and unscrew out the PCB that this component have soldered in.c40243d8-cf4c-4923-b01c-275b76413f28.jpg
297f57d3-e54d-4a39-9705-1b60be54ed8c.jpg23707d23-08b4-4207-8360-4ae03fdb70ea.jpgThe component will look somewhat like these. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 12, 2013 | Televison & Video
Nec split system air con will not respond to remote control.
Remove batteries and replace with new batteries and restart. If still problem, unplug DC wire to indoor display sensor and plug it after a minute. Now try with your remote. If still problem, try with another remote. If no result, PCB receiving sensor defective. Replace display sensor or PCB
Jan 27, 2011 | Heating & Cooling
Carrier 42csr series cannot turn on. Only green light at "operations" flashing. what can I do to start it or put it off? the remote doesn't seem to work on it right now.
Transmission problem between remote and PCB sensor. Please replace batteries in your remote and try. If not try with another same type remote. If still problem persists, problem with receiving sensor in PCB. Repair or replace it.
Jan 16, 2011 | Carrier 52PQ307 Wall/Window Air...
Where is the idle air control sensor locatyed at on a 2003 ford escort zx2
The idle air control vavle is located on the driver side of the intake manifold, below the throttle body. You'll have to remove the air intake to see it. It is held there by two bolts.
Feb 14, 2010 | 2001 Ford Escort ZX2
Remote sensor in the TV
Remote sensor is locketed on pcb it an be replaced
May 11, 2009 | Televison & Video
Service reqd E511
I was able to get hold of a schematic diagram to locate the part number for sensor :
part code 2090463 SENSOR TR-0
When I inspected the original part the pcb was cracked therefore the sensor was unable to dectect the 'mirror' which is a silver square located on belt on photo con unit.
If you require a copy of the schematic diagram (pdf) let me know an address to send it to.
Regards
Rob
May 22, 2008 | Epson ACULASER CX11NF All-In-One Printer
Vs-50605 Mitsubishi
Infrared pcb is located inside mirror cavity mounted to CRT support frame.Follow lead to signal PCB--is it plugged in,to the correct location??----Then suspect bad infrared detector PCB.Or,possible bad signal PCB.
May 27, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Toshiba 62HM195 62 in. HDTV DLP TV Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
