Question about Comdial Avaya Partner ACS Phone
Change number of rings on incoming call before it goes to VMS
We are using partner mail vs release 5. Currently its set to go to the voice mail after 4 rings. We would like to change it to 2 rings. we've looked all over the manual and tried different things and can't seem to change it. any idea on how to change it?
    President:
  • Comdial Master
  • 860 Answers
Changing the vms hunt delay on a Partner ACS system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#505"
the display should say vms hunt delayand mode:
enter 1 for day mode or 2 for night mode
enter line you want to program in 2 digit format (line 1 =01)
enter number of rings (2)
press feature "00" to logout
hope that helps
Posted on Feb 13, 2009
Voice Mail Pick up
enter in "#505"
the display should say VMS Hunt Delay and mode:
May 02, 2013 | Avaya Lucent / Partner 206ec Expansion...
We need to set up a voice mail for an extension that has not been used in years. When I press intercom 777 and enter extension it tells me to enter password which no one in the office knows anymore. When...
The default password on partner voicemails is 1234. The reason for the call returning to the extension that transferred the call to the new extension is probably because the cover vms isn't set up for the new extension.
To check the vms cover for that extension, at either extension 10 or 11 press feature 00 and press the left hand intercom button twice. The display will say system programming.
Enter #310, the display will sayAutomatic VMS Cover Extension:
enter in the extension number of the new extension.
The screen will say either "1 assigned" or "2 not assigned"
enter in 1 (assigned)
press feature 00 when finished.
Sep 30, 2010 | Avaya Corded Phone avaparp18d
I have Partner mail VS release 5. When someone calls in they get the receptionist voice mail(10) instead of the day menu prompt of the automated attendant. How do I get messages to go to the automated...
I'm guessing that you changed the setting in the line coverage ext program (#208) or group call distrib (#206). Make sure that the settings for the lines are set to 1-assigned and not 3-VMS cover in program #206. In #208 there should be no data entered for the line if its not set up as a private line.
Jun 17, 2010 | Avaya Lucent Partner 616 Phone
The phone rings 3 times and goes to voicemail on the 4th ring. How do I change it to pick up on the 8th ring?
I don't think its a good idea to back the vms cover rings to 8. The furthest I'd go is maybe 6.
Changing the VMS cover rings on a Partner system is done on either ext 10 or 11.
enter in "#321"
the display should say VMS Cover Rings and ask for an extension number
enter the extension number you wish to change
The current ring data should be displayed
enter in new data (8 ring if you wish)
Dec 10, 2009 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
Oct 06, 2009 | Lands Phones
How to change Auto attendent Dial O to ring at multiple ext
First you will need to add extensions to a group X in #502
When you login to administrative mailbox you will change you operator extension to 7X. Phones in the group will ring
Apr 22, 2009 | Avaya Lucent Partner 616 Phone
Voice mail
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
3) dial "#506"
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Feb 03, 2009 | AT&T Lucent MLS-12D Phone
Installing partner mail vs r4.1
check the voice mail ports. Can you dial them and have them answer?
Also check that each extension is programmed to hunt to voice mail in the partner programming
Jan 05, 2009 | Avaya AT&T Partner Phone
Lands Phones Logo
3,204 people viewed this question
Top Comdial Lands Phones Experts
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
