Question about LG LDF7932ST Builtin Dishwasher
Lg dishwasher arms not spinning - LG LDF7932ST Builtin Dishwasher
4 Suggested Answers
  • 423 Answers
SOURCE: Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Posted on Apr 04, 2009
  • 464 Answers
SOURCE: Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Posted on Nov 08, 2009
heatman101
  • 43501 Answers
SOURCE: LG dishwasher bottom arm not spinning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syte
Posted on Sep 29, 2010
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
It wont clean the dishes. The water is going in I can hear it but My thoughts are the arms are not spinning. I did check and they are not obstructed but its hard to see if they spin. How can I tell if...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 07, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
LDF7932ST LG dishwasher top and bottom arms not turning. Diagnostic test mode "power+spray+ rinse" does not work.
I put a new lower spray arm and very little water comes out of it. There is quite a bit of water that comes out of the middle and top. The top does not spin but has quite a bit of water and the middle spins really good.
Jun 25, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Nov 07, 2009 | LG Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Sep 04, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Dishwasher problem
The LG dishwasher family has a cool feature that alternates the full wash/spray power between the upper spray arms and the lower arm.
It is called Vario - with a motor that drives a check valve to route the water.
So, If you just open the dishwasher while it is running and look to see if all the spay arms are spinning, you will be disappointed.
Now, if you are having problems with dishes not getting cleaned, we need to take the next step. Post back what you find.
Good Luck!
Apr 09, 2009 | LG LDF9810ST Built-in Dishwasher
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
Top arm doesn't spin
It is important to know that the upscale LG diswashers alternate between washing the top and bottom rack. So it is normal for some arm to not be turning at certain times.
Also, if this dishwasher is set to half load, bottom only, the top arm will never turn.
Oct 16, 2008 | LG LDF8812 Stainless Steel Built-in...
LG LDF7932ST Builtin Dishwasher Logo
195 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
