Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
ICE MAKER IS NOT WORKING RED LIGHT IS FLASHING NEXT TO ON-OFF SWITCH
  • KitchenAid Master
  • 4,654 Answers
Sounds to me your ice level optics are bad. Click Here=> 4389102 Ice Level Control Board
I will be here should you have questions, Thanks Sea Breeze
Posted on Nov 09, 2012
catriver
  • 878 Answers
SOURCE: Ice Maker
Sassy, the red led should flash 2x followed by a pause, repeatedly with the door open. If you hold the left side flap down, it should stay on steady. If it does this you know the optics are ok. Sounds like you just hooked it up to water. The ice maker thermostat has to be at least at 17 degrees before it will call for water and then it will have to prime the lines to the ice maker first before filling the mold. The easiest way to reset the icemaker is to unplug the refer for 30 seconds. Other things you want to check are that the ejector blades (blades that push the ice out) are in the 2:00 position. Check to see that the fill tube that fills the mold is not frozen over. I have a feeling that your lines just needed to be primed. Hope this helps you understand this unit a little better...Catriver...post back.
Posted on Apr 05, 2007
SOURCE: Ice Maker not working
water dispenser works but hte ice maker does not work
Posted on Jun 18, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
SOURCE: Red Light Flashing by Ice Maker on and Off switch
Red light flashing and NO ice. I used a hairdryer to hopefully clear the frozen waterline and it made 1-ONE row of ice and stopped and the red light still flashing. help!
Posted on Nov 12, 2008
aasc
  • 1606 Answers
SOURCE: ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Posted on Sep 05, 2009
Power surge caused appliance to go out. refrigerator ice maker now not making ice. has water on but no ice help
Reset the ice maker:
Locate the switch next to the water filter status light.
Press the light switch five times in 10 seconds or less.
Wait for the status light to change from red to green.
Mar 02, 2015 | Whirlpool Refrigerators
Saeco odea giro flashing light
Alarm light:
permanently on (one or more events): signals the machine is out of coffee, that the water tank is empty, or the drip tray is full.
on and slowly fl ashing (one or more events): signals that the Brew Group is not
inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed,
the service door is open.
•on and quickly fl ashing: signals the need to prime the water circuit.
Jun 24, 2014 | Saeco Odea Go
Saeco Giro flashing
Alarm light:
on and slowly fl ashing (one or more events): signals that the Brew Group is not inserted, the grounds drawer is not inserted, the cover of the coffee hopper is not closed, the service door is open.
Jun 24, 2014 | Saeco Coffee Makers & Espresso Machines
Blinking red light
Alarm light:
Jun 22, 2014 | Saeco Odea Go
Can you you tell me why there is a flashing red light on the coffee machine
Descaling light:
• on and fl ashing: signals the need to perform a descaling cycle
Machine ready light:
• permanently on: signals that the machine is ready for use.
• on and fl ashing: signals that the machine is warming up.
Alarm light:
• permanently on : signals the machine is out of coffee, the water tank is
empty, the drip tray is full or the dregdrawer is full (in this case, also empty
the coffee grounds drawer in order to prevent failures).
• on and fl ashing slowly: signals that the brew group is not inserted, the
dregdrawer is not inserted the coffee bean hopper lid is not on, the service
door is open or the steam/hot water knob is not correctly turned to the
desired position.
• on and quickly fl ashing: signals the need to prime the water circuit.
Jan 13, 2011 | Saeco Odea Go
Seee note on ice maker stopped working, blinking red light
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
rtwywy
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Oct 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
