Question about Panasonic CT-36D31 36" TV
Lost sound while watching TV on cable. Checked all remotes, nothing helps. TV does have sound for VCR playback. What is the problem?
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Likely the tuner in the set which aside from signal also processes audio---also if the set has a headphone jack take a look at that as it could cause this---small but some chance.
My bet is tuner
Posted on Nov 08, 2012
Since today i have had a snowy sound On channels 1-5 the picture is there, they are ok on just normal tv and they are ok through a vcr but not dvd recorder.....i have tryed settings,changing scart...
Hi, Unfortunately I am a bit unclear on the snowy sound issue but what your describing otherwise sounds like you are trying to watch tv via the dvd recorders built in t.v. tuner, this is possible usually just with a coaxial connection. ( a cable tv cord ) The out to t.v. terminal on back of recorder must be connected to the in from ant./cable on the back of the tv set. all other connections are for higher definition playback. Thanks for trying FixYa, I hope this helps, and good kuck-Prodzilla
Apr 13, 2011 | Televison & Video
Vcr is not talking to the tv
If your TV is all digital and does not have an analog NTSB tuner you will have to use component input connections from the VCR to the TV instead of the RF (antenna) cable connection. First try pressing the TV/VCR button on the VCR remote to provide a direct VCR feed to the TV.
Jul 01, 2009 | Televison & Video
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
My jvc hr-s8700 has no hifi stereo playback
The VCR stereo playback sound is only available through the AV/SCART connection and will not work through the coaxial antenna cable.
Cheers
Jan 08, 2009 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Remote operation ( remote will not activate vcr )
Sounds dumb, but had the same problem. I removed the batteries and double-checked that I had placed them in their respective slots correctly. If in doubt, use a completely NEW set of bats. Use the best bats you can afford. Also make sure you are pointing/aiming at the VCR sensor straight on; possibly the front of your VCR case is dusty/dirty? Just lightly dust off. No detergents. Good luck.
Oct 24, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Proscan vcr psvr70
Sounds like it's wired up wrong...try this:
take cable line to VCR in, VCR out to cable/receiver box(if you have one) then box to TV...it sounds like the vcr is getting the channels from the box and not the vcr...you will need to have the vcr scan the channels (round in the settings menu) You will also be able to watch and record 2 different things.
Oct 18, 2007 | Proscan PSVR70 VCR
Remote control code
That doesn't sound quite like the usual procedure for programming a universal feature on a remote. Should have to put the remote in TV mode, then press something to get it into programming mode, then put in the code for your particular TV.
Oct 17, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Panasonic CT-36D31 36" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
